Old 12-29-2009, 03:25 PM
sfrank69 sfrank69 is offline
Default which spark plug ??
I bought a 66 China 2 stroke setup..
all of it was in the BOX except the spark Plug???
it is a low compression straight up plug
( not a slant one)
I will buy a spark plug locally
but which one do I want to BUY ???
please email to me directly
hfrank24@comcast.net
and suggest a spark plug by NUMBER !!???
thanksssssss
Old 12-29-2009, 03:38 PM
Gareth Gareth is offline
Default Re: which spark plug ??
NGK B6HS is what you need. Try Napa.
Old 12-29-2009, 05:42 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
You can also use a NGK B5HS if it's real cold outside!!
Old 12-29-2009, 11:36 PM
Dave31's Avatar
Dave31 Dave31 is offline
Autolite 425 works great as well as the Champion L86C
Old 01-01-2010, 10:27 AM
wes's Avatar
wes wes is offline
I like the NGK B6HS but i live in the hot desert, correct me if i am wrong but i beleive with NGK the higher the number the cooler the plug.
Old 01-01-2010, 11:29 AM
Nougat Nougat is offline
Yes, higher number equals cooler plug. If you're running hot in the desert, try a B7HS.
Old 01-05-2010, 10:42 AM
CaptJ CaptJ is offline
NGK B5HS = 40 - 80 Degrees F
NGK B6HS = 80 - 110 Degrees F
