Old 12-25-2009, 05:30 PM
Vistaman73's Avatar
Vistaman73 Vistaman73 is offline
Chat Box Junkie
Question Clutch problems
here is what i did.
1. i take the flower off.
2. i take the clutch plate off.
3. i see the pads.
in this situation, should the left side sprocket move freely, mine does not.
with the clutch put together no matter how much i adjust it, it would not didengage. what is the matter with this crappy clutch please help me. thank you.
Old 12-25-2009, 05:50 PM
LAboy's Avatar
LAboy LAboy is offline
Default Re: Clutch problems
I have the same problem...
Old 12-25-2009, 05:57 PM
Venice Motor Bikes's Avatar
Venice Motor Bikes Venice Motor Bikes is online now
Custom Builder / Dealer
There are many tiny bearings in the large clutch gear... they probably went bad!
Jim (manic mechanic) posted a comp drawing of the clutch assembly here somewhere.
Pull off the large gear with the gear puller tool that came in the engine kit & see if the bearings are bad.
Old 12-25-2009, 05:59 PM
skjjoe's Avatar
skjjoe skjjoe is offline
here it is http://motorbicycling.com/f30/animat...haft-8939.html
stay thirsty my friends
Old 12-25-2009, 06:42 PM
Nougat Nougat is offline
If it's a new kit, turn the center nut on the ring gear with the plug wrench. It'll pop free, just stuck from sitting.
Old 12-25-2009, 07:41 PM
Vistaman73's Avatar
Chat Box Junkie
Thumbs up Re: Clutch problems
OK, went back out and took a hammer to the pin on the left side. broke free, must have just stuck from sitting (it's brand new). thanks for all of your help.
Old 12-25-2009, 09:08 PM
skjjoe's Avatar
glad you got it fixed
Old 01-07-2010, 05:31 PM
Pedalman Pedalman is offline
Originally Posted by Vistaman73 View Post
here is what i did.
3. i see the pads.
scratg
First time builder here, I just turned that "flower" nut out about 360 degrees,put that stop bolt back in, after checking clutch lever(and looking at clutch plate turning and not turning with clutch lever pulled in and letting it out).If someone said the exact thing sorry in different way excuse me.xct2xct2xct2xct2xct2xct2
