Old 12-21-2009, 12:34 AM
Xiodinc's Avatar
Xiodinc Xiodinc is offline
Question I can't pedal my bike.
OK so, here's the problem.
I can not pedal my bike at all. When i do, it is hard, and the engine chain always falls off. I usually go about 10 feet and really slow when this happens.
Although, if i do a running start, Jump on my bike, and start the engine, everything works fine.
I want to know why this is happening and how to fix it please.
Old 12-21-2009, 01:12 AM
stv1jzgte stv1jzgte is offline
Default Re: I can't pedal my bike.
Ok you have to make sure that the rear wheel is on straight not only this but the motor chain runs straight ie both wheel sprocket and drive sprocket are in the same line, stand behind your bike and you should be able to see if everything is square.
It could be that the motor is not straight the rear wheel not aligned or it could be the idler is not tracking true. these are the main thing to check out.
let us know how you did.
edit
When all is straight there should be very minimal drag fron the drive sprocket and you should roll and pedal just fine
Old 12-21-2009, 01:23 AM
http://motorbicycling.com/f4/cant-pe...spin-9846.html
Old 12-21-2009, 09:58 AM
Venice Motor Bikes's Avatar
Venice Motor Bikes Venice Motor Bikes is online now
Custom Builder / Dealer
Post some pics of how you have everything set up... we'll get you riding!
Old 12-21-2009, 11:08 AM
Xiodinc's Avatar
Ok so, I can ride perfectly fine, no problem there, just PUSH start it and hop on, but when i try to pedal start, the engine chain falls off. I can ride the engine for hours on end without any problems. Only when i pedal, is when the problems occur.
Also, how would I be able to align the rear sprocket, if that is the problem?
Old 12-21-2009, 12:50 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
I had to use washers on the wheel axle on one of my builds to move it over,,, Also how is your clutch...
Old 12-21-2009, 03:45 PM
Xiodinc's Avatar
clutch is fine.
everything is fixed now. the chain was too loose
