Old 12-16-2009, 05:57 PM
Vistaman73's Avatar
Vistaman73 Vistaman73 is offline
Chat Box Junkie
Question Break-In Procedure
Hi, I would like to start a new thread all about how to properly break in your engine.
Which way is right? Which way is wrong? How have YOU broke in YOUR engine? Do you reccomend your style? Do you regret anything? Please feel free to leave tips. I still need to finish my bike and I want to know how to break it in. Thanks!
Old 12-16-2009, 06:21 PM
Nougat Nougat is offline
Default Re: Break-In Procedure
I'm new to these motors, so take what I say with that in mind.
I favor quick fast break-in: Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
Old 12-16-2009, 09:07 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I agree with everything in the link above!!!
I use 24:1 mix for the first 2 gallons & ride the heck out of it!! (always warm up the engine completely before going to WOT!!!)
Then, after the two gallons of 24:1 mix, I switch to 32:1 for the life of the engine.
My engines all run strong & fast using this method!!
Old 12-16-2009, 10:00 PM
Finfan's Avatar
Finfan Finfan is offline
I used fossil oil at 20:1 for the first 2 gallons, then fossil oil at 25:1 for the second 2. Then I went to synthetic oil at 30:1 although that may be a little too thick. The reasoning is that the fossil oil will allow the engine to wear in properly. Then you switch to synthetic to keep it from wearing out.
As far as use I would say to take it easy for the fist half hour or so. If there are any major problems with the build they should show by then. From there ride it like you are going to normally.
-and-
I'm not lost, I'm exploring!
Old 12-17-2009, 08:07 AM
wes's Avatar
wes wes is offline
I fired up my last motor and it was suggested to let it sit at idle for 30 min in front of a box fan, i let it sit in front of the fan for about ten minutes at idle and took off, for the first 4 tanks i ran 24:1 and never held the throttle and a steady speed for to long, what i mean is i constantly feathered the throttle, i speed up for a few minutes and than let off and slow down for a few, than i speed back up but i kept away from WOT for too long for the first hundred miles or so, and my motor is a torque monster with a 36t sprocket and it is very responsive with Jims intake and a breathable exaust, Good luck and welcome to the forumn!!!
Old 12-17-2009, 08:18 AM
Bikeguy Joe's Avatar
Never idle an engine for any long period during break in, that's the worst possible thing you can do.
Old 12-17-2009, 09:35 AM
DonnnN's Avatar
DonnnN DonnnN is offline
I broke in mine with synthetic 2 stroke oil.. 24:1 during break in.. Never rode it longer than 30 minutes.. After break-in Im using 32:1.. Running strong and fast.. ; )
Old 12-17-2009, 01:42 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
i used Opti-2 at 60 / 1 ratio, and full throttled it from day one. i also took the time to basically blueprint the motor before i ever installed it, and then i put it on backwards.
i'm running about 80 / 1 right now, and the motors three weeks old with a few hundred miles on it.
almost all of those miles are WOT.
i don't recommend my method. at least not yet. if the motor lasts a few thousand miles, then i'll recommend it.
Old 12-17-2009, 04:01 PM
I concur!!!
Just get out & ride it!
Old 12-17-2009, 04:24 PM
Vary the throttle amount and engine speed.
Don't do a lot of closed throttle downhill runs. (never a good idea with a two stroke).
Check your plug after the first 15 minutes if all else is O.K., sooner if it's not. (to make sure your mixture is close).
Don't go far from home for the first hour of operation, though you'll likely need to tweak the installation, not the engine itself beyond maybe a carb adjustment.
