Old 12-11-2009, 02:00 AM
DVBikes DVBikes is offline
Banned
Default Stubborn Clutch
Well based on the fellow members i should ask the pros to help me
ok so my clutch has been trash since i got the motor.
now after like 500 miles im sick of my crappy clutch
At first the clutch worked great (the first 2 days) then about a month later i took the spring out from the arm.
then worked
and then that 2 faded then i adjusted the flower
than i took the ball bearing out worked great
adjusted now the clutch wont lift up and i tried all sorts of shims
PLEASE HELP ME
My quote should be "Its always SOmething new"
Old 12-11-2009, 05:31 AM
Bikeguy Joe's Avatar
Default Re: Stubborn Clutch
You took the ball bearing out and it worked better?
That is not possible.
Old 12-11-2009, 10:51 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I agree with Joe!! That's in there for a reason!
Do you use the pedals when taking off from a dead stop? or do you just clutch it like a motorcycle?
That could be why your clutch is fading...
Old 12-11-2009, 12:42 PM
Banned
no i push to pedal start it always a umsh behind it
Old 12-11-2009, 12:47 PM
Re "adjust" the flower nut back to where you started.
Put the ball bearing back in.
Push the cable stop TIGHT against the clutch arm, pull all the slack out of the cable, and tighten the cable stop (helps to have three hands or another person)
Read my signature.
Old 12-12-2009, 01:15 AM
Banned
well i spent 3 hours this mornig and fixed it
Old 12-13-2009, 01:55 AM
DonnnN's Avatar
DonnnN DonnnN is offline
Thas good news..
Old 12-13-2009, 09:05 AM
So what was the problem?
Old 12-13-2009, 05:46 PM
Banned
well i have a ball bearing in there now from a chain from a fan. And played with the flower and riding in the dark to make sure no slippage. i still need to order a new throttle handel.
