Old 06-06-2008, 06:29 PM
haolehonu haolehonu is offline
Default kill switch
so i had to disconnect my kill switch to get the bike started, and I am wondering if it is bad to kill it via clutch? also how easily can i switch it with a motorcycle kill of higher quality?
i love my spookytooth!
Old 06-06-2008, 06:33 PM
Bikeguy Joe's Avatar
Default Re: kill switch
You can buy a good kill switch at Radio Shack or anywhere you want that has a monentry switch. I kill all my bikes with the clutch, however. No problems.
Old 06-06-2008, 06:49 PM
no kill switch means no cable up my handelbars....me gusta! gone.
Old 06-11-2008, 07:08 PM
tinkerfinger's Avatar
tinkerfinger tinkerfinger is offline
Though you may here that its no problem to kill the motor with the clutch, the truth is, you dont see the problem till it wont run anymore. Technically any on-off toggle can be used as a kill switch. flip up for on, down to kill. mount it under tank, or somewhere else. It doesnt need to be on the bars. go crazy with it.
If your not sure, ask a friend first!
Old 06-12-2008, 04:31 PM
yeh I think im going to mount it under the main bar of the frame just under the tank. prolly goin to try a motorcycle kill switch
Old 12-23-2008, 07:38 PM
motor_head's Avatar
motor_head motor_head is offline
can get toggles cheap <$2
Old 12-24-2008, 07:19 AM
whatchootalkinboutwillis?
Using the clutch to kill the engine has no ill effects whatsoever. I have done it with dirt bikes and motorized bikes for a looooooooong time, no problems.
Old 12-24-2008, 07:20 AM
But yes, a good switch is cheap and easy to install.
Old 12-24-2008, 08:57 AM
misteright1_99's Avatar
AND trying to kill the engine with the clutch, when the throttle is stuck wide open, and your heading towards an intersection, doesnt work very well........
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
Old 12-24-2008, 10:10 AM
donuts31 donuts31 is offline
That's bad advice Bikeguy Joe. Using a clutch to induce sudden stoppage is bad not only for the clutch with increased wear, it is not good good for the engine. You may do this regularly with normal motorcycles but the HT engine is notorious for its poor clutch and difficulty in finding replacement clutch pucks.
You dropped the ball on this response.
OP, if you can't use your kill switch, kill your engine with the choke.
