Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 06-06-2008, 06:24 PM
misteright1_99's Avatar
Default HT Main Jet Size?
Does anyone know what size the jet is in the 48cc Happy Time? I read Normans carb post and he lists the main jet as being .026 for stock, but he might have been talking about the larger HT engine. Is it the same size for 48cc as 68cc since they use the same carb? Doesnt seem like they would be. Any help would be appreciated..
Old 06-06-2008, 10:27 PM
spad4me's Avatar
spad4me spad4me is offline
Default Re: HT Main Jet Size?
I really think they use the same carb.
I modified the dog snot out of mine.
My needle was as straight as a nail.
It is radically double tapered( too much work but very nice)
It is lengthened and adjusted with extra washers on top of the slide.
My main jet was too large even after I tapered the needle.
I am too cheap to buy the complete drill bit sizes so the local dollar store bits last just long enough to drill brass.
Then solder and try again.
Old 06-06-2008, 10:41 PM
Yea the carbs all look the same, but I would think that the larger displacement of the 70cc would mean it would use more gas, therefore a larger jet. I had the set of jet drills when I was doing motorcycles, but sold them along with all my jets...I have done a bit of porting and exhaust mods and think I need to go up a size on the jet, and start the needle back on the top slot...
Old 06-24-2008, 07:48 AM
RLorange RLorange is offline
Thumbs up Re: HT Main Jet Size?
The Jets are the same for both the 70 and 48 engines and are 0.70mm or close.
The 70cc needs a bigger jet for sure. Luckily the jet unscrews from the pin fuel well inside the carby. Even luckier still Dellorto PHBG Main jets are a perfect fit!! and cheap at only $5.
I would try a 0.78mm to 0.80mm or for the 48cc engine and 0.80 - 0.85mm for the 70cc engine. You may have to compensate by raising the clip on the pin.
Very handy that the Chinese engineers thought to match the jets with Dellorto's
Old 06-24-2008, 05:38 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
I went and checked on my metric drill sizes for the 70cc main jet mine was drilled at 0.70mm and was a little to rich I soldered it shut and drilled it for 0.65mm which is working good this was done on a Dax 70 cc my other china girls are 0.065 some that I've looked at are slopply drilled and could use a solder shut and redrill my elevation here is3200 ft above sea level and the temp is in the 90s so air density is like running at a higher elevation so a guy will need maybe need a slightly smaller jet during the summer.
Best to check with the plug nice light brown is in the ballpark.
Ok for you guys who want it in american measurements
0.70mm= 0.026"
0.65mm=0.025"
Hope this will help
norms-iron-works.tripod.com
Old 06-25-2008, 07:09 AM
Good info about jet sizes... You found the 0.70mm too rich?
Well I found that by using a bigger jet you get more fuel at full throttle but this only works if you raise the clip to compensate so that it is not too rich at lower revs.
My logic was that my engine was too rich at lower revs on the middle clip setting and too lean at higher revs when the jet size matters more. So by running a bigger jet and raising the clip you reverse this now having more fuel at higher revs and less at lower revs.
I promise the engine is much happier, uses less fuel and the spark plug muffler and combustion chamber are all cleaner.
I am considering running a pilot jet! I will drill a small hole in the carburettor and set a hypodermic needle into some QuickSteel epoxy resin creating a tiny second jet. This should help smooth the transitions in throttle.... Then I will have to drop back in size for the main jet
Old 06-25-2008, 07:18 AM
Pablo's Avatar
Pablo Pablo is offline
I will measure my spare carb jet today on the comparator. Something I've been promising to do since Norman discovered my needle didn't have a (proper) taper, way back when.
Rather than buy new jets, I may drill this one out to whatever drill comes closest to .80mm and see what happens.
Old 06-25-2008, 07:43 AM
Ah yes my Supplier told me a similar story about the needles some batch with the wrong taper... Hmmmm maybe I have one of those that would explain how I am running such big jets.
Old 06-25-2008, 09:12 AM
Pablo's Avatar
My spare carb jet is .6958mm (.7 mm) (.6958mm = .027")
This was on a 67cc engine, standard carb - that arrived in December with a fat needle and wouldn't run worth a lick until the needle was turned down.
As stated, I need to find what size drill will be closest to .8mm (.0315") (maybe there is a .8mm drill!) and drill this jet out, just for fun.
Old 06-25-2008, 10:00 AM
#68 Drill = .031 Pablo
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
