Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Tavern > The Tavern
The Tavern Kick off your shoes and sit back with your favorite beverage and enjoy talking about whatever you like.
Old 12-05-2009, 04:27 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default Hey Joe
What do you think of this for the front of my ebike.... I'm not kidding
Tas gas bicycle motor front mount motor - eBay (item 170413544483 end time Dec-06-09 09:40:38 PST)
Old 12-05-2009, 05:59 PM
Michigan Mike's Avatar
Michigan Mike Michigan Mike is offline
Default Re: Hey Joe
Deacon,
I think it's a cool idea ... but don't know anything about these particular motors.
Michigan Mike
"There's never a reason to be unkind."
Ravi Zacharias
Old 12-05-2009, 07:13 PM
deacon's Avatar
Default Re: Hey Joe
joe had one he should be able to give me a hint. I know you have to drag start them which would be a pain in this area but with the emotor it should be a breeze also the two might give me good speed and good range. Coast on the gas suppliment it with e for speed and power. Its a small engine.
Old 12-06-2009, 11:41 AM
deacon's Avatar
Default Re: Hey Joe
never mind I got outbid rofl....
Old 12-06-2009, 12:22 PM
Default Re: Hey Joe
Too bad ... I was looking forward to reading about the build.
I think it would be neat to have a bike with gas/friction drive on the rear and an electric hub motor on the front. The gas motor could do the "heavy lifting" and the e-motor could be used to ride quietly through town. Somebody somewhere must have this setup.
Michigan Mike
Ravi Zacharias
Old 12-06-2009, 12:33 PM
deacon's Avatar
Default Re: Hey Joe
I agree neither drive would have to be very strong. The small thirty five or so cc gasoline and a 300watt or so emotor would be a good combination. The motor to start it up and the gasoline to cruise and run up the hills. A little e help on those if needed. I wonder if the gasoline engine would recharge the battery since the wheel would be turning the motor in generator mode. Might be something to look at there.
Old 12-06-2009, 12:59 PM
Default Re: Hey Joe
That sounds possible ... but I don't know enough to say whether or not the recharging would work.? You know what Yogi Berra said:
"In theory there is no difference between theory and practice. In practice there is."
But even if the gas motor won't recharge the battery, it still sounds like a good system. The recharging can always be done at home as usual.
Michigan Mike
Ravi Zacharias
Old 12-06-2009, 01:10 PM
deacon's Avatar
Default Re: Hey Joe
yes i figured the battery would be used only now and then so it could be small and lighter weight. I was thinking of just a short bobtail trailer with the batteries hanging on either side. Just a small 24v system Since it wouldn't be used much it should be pretty easy to do. I wouldn't bother with an expensive hub motor but go with a cheap scooter motor and friction drive on both wheels.
I wish I could figure a way to convert the rhino drive to gasoline. It would be idea but the banking of the chain drive beat the last motor I had to death trying to run a generator. I think the wheel would be just as bad or worse.
