Old 12-04-2009, 10:17 PM
Default Re: first build,tools needed?
Originally Posted by macattie88 View Post
thanks jim...i checked out your website and im interested in the motor mount and sproket and mount...i have a delmar...will these items help as far as ease and final finish quality?
The sprocket adapter and sprocket will definitely help with ease of assembly, and offer a far superior finished product in terms of vibration and maintenance. The engine mount offers ease of assembly, and enough vibration isolation to prevent frame cracking.
Check the coaster brake arm for the hub model...if it's the Falcon CFE-10, I would really recommend replacing it with the shimano CB110 / CB110E.
I assembled a Schwinn Legacy that had this's the post.
Old 12-05-2009, 12:35 PM
Humsuckler's Avatar
Humsuckler Humsuckler is offline
i blew up a falcon hub as well. the guy at bikedump in ottawa said it was inferior and they all do it....
i forgot about what i was posting in lolz
you need blue threadlocker. nail polish works too i have hered.
metric wrench set from 8 to 15mm
(i think the tank nuts are 8mm...)
you should also remove the studs for mounting the engine and intake/exhaust and replace them with 10mm metric bolts. the studs will break, mark my words. an atv/motorcycle dealership should have metric bolts. just ask them if you can go look in their hardware bin for what you need and offer them some money.
lockwashers of course.
make absolutley crtain your chain tentioner is tight and correctly aligned.
if you have a problem with teh chain rubbing the tire, you should install the sprocket with the dish facing out.
most importntly, do not forget about the boards, and remember we can help!
