Old 12-01-2009, 05:51 PM
mt690ju mt690ju is offline
Default Rear Sproket Fit
Hi, i'm new to the forum and live in Key Largo, Fl. Just ordered a Black Stallion 80cc angle fire slant head motor kit and should receive it by Friday. I have a Murry beach cruiser that I was going to use since the running gear is pretty uncomplicated, but I just picked up an Electra with a 7 speed shimano hub on the rear. Is it possible to put the 44 tooth rear spocket on the shimano hub or will it need to be modified?
Jim
Old 12-01-2009, 07:38 PM
gubba gubba is offline
Default Re: Rear Sproket Fit
if the electra is NOT a coaster brake style it should work fine.
i have found that the shimano coaster brake arm will not acccomadate the rear sprocket and fiber spoke spacer. you cannot get the brake arm to connect to the hub.
i just installed an 80cc kit into a vintage 1963 murry beach cruiser and it is great. you DO have to bend the brake arm away from the sprocket a little to keep the nuts from hitting the arm. this is common with all coaster brake hubs.
keep us posted and have fun.
stay dry
gubba
Old 12-01-2009, 07:54 PM
DOC BOLM's Avatar
DOC BOLM DOC BOLM is offline
Save yourself some trouble and call Jim at Creative Engineering in Clearwater at 727-768-9510.Tell him Harleys Dad sent you.
You never know what you might know,you know
Old 12-01-2009, 08:31 PM
Thanks for the advice. The electra has some sort of pancake brake assembly just outside the hub, and is not a coaster brake. I'm going to remove the rear wheel tomorrow and check some dimensions. If all else fails, I'll take Doc Bolm's advice and call Creative....
