Go Back   Motorized Bicycle: Engine Kit Forum > Electric Bicycles E-Bikes > Motorized Electric Bicycles
Motorized Electric Bicycles The motorized electric bicycle is a quiet and efficient form of transportation for general commuting.
Old 11-29-2009, 06:35 PM
professor's Avatar
professor professor is offline
Default The Gas/alternator powered E-bike
I have been intensively working on this since September. The bike is a Mongoose FS with the rear suspension tied down (wound the rear spring to limit travel and KEEP the motor drive chain on).
Using a 250 watt scooter motor,chain and sprocket to a jackshaft made out of a freewheel mx rear hub. From there, a bike sprocket welded on the other side of the jackshaft, driving a 42 tooth bike (standard?) chain ring adapted to a China girl rag joint.
Works OK, around 14 to one sprocket ratios and 13 mph speed with 24v batterys feeding it.
The following is WITHOUT the 24volt battery pack and instead uses an engine driving an alternator w/ a small 12v feeding the field circiut.
The alternator I am using is a Ford, external regulator style (NOT using the reg. at all). It has the power output directly connected to the scooter motor wires, with only a switch on the handlebar to shut it off and on.
Scooter motor speed is controlled by throttle position of the gas engine and the on/off switch. Later I will add a 2nd switch to the throttle control to kill big power at idle.
I am using a 12volt batt. to put current into the field circuit. Later, I want to add a snowmobile regulator (try to anyway) and a diode to charge the battery off the big output of the alt during use.
One of the tests I did was to remove the alternator and drive a 450w scooter motor as a generator. This did NOT work, the bike did move at a snail's pace, yes, it did generate current, but not much.
2weedwacker motors were tried. In a geared- down mode, one labored to just spin the alt. (probably a tired engine). The other, labored to spin both alt and drive motor with out load in direct drive - bike laying down- not ridden.
Here is what worked but the engine is too heavy for the rack mount- the HF 79cc is a sweetheart engine. With one to one ratio, spinning the alternator, I registered 50 volts at full engine rpm (3600).
This was enough to launch the bike with just a bit less inital thrust, than when it ran off batterys (not having the big reserve of amps), but still acceptably quick, and once getting up to speed, had to dial back to near idle to keep from overspeeding the scooter motor and maintain level speed (around 13-15 mph).
Having seen the alternator powering the bike, I swapped engines. To a 50cc Tehumseh snowthrower engine.(looking for light wt.)
This was a slug, it barely propelled the bike off idle and took forever at ful lthrottle to get up to speed. It is rated at 3 hp - maybe wound tight? But no torque.
The HF was a big block with a blower compared to the 50cc.
Winter is bearing down on the E-bike project. We have had an exceptionally warm November, allowing me to get farther than normal on this project.
I plan on pulling the 6 hp Techumseh off the 24 inch red bike and put it on the back of the Mongoose. Even with that 10 pound engine, the bike will weigh over 85 pounds, BUT total wt. won't be excessive because I weigh 135#. I think the 6hp will have enough torque to replicate the performance of the HF engine and it is ten pounds lighter.
I am out to ride with the same speeds and mode as a normal bike. I just don't want to deal with batterys and controllers. A Milk crate will cover the engine on the rack.
I will be New York legal (with this bike at least).
Hope the info is useful.
Old 11-29-2009, 07:14 PM
wdbtchr wdbtchr is offline
Default Re: The Gas/alternator powered E-bike
Is the 6 horse the 98cc Tecumseh?
Old 11-29-2009, 07:45 PM
professor's Avatar
Yes, it is off a Toro S-200 snowblower.
Had to put a idle stop tab on the carb throttle lever to be able to use it in a normal fashion. (and not the revved-up single speed the blower had). Real well- made old engine.
Old 11-29-2009, 07:56 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
professor do you have some photos? of your project wold be cool to see it. thanks!!
Norman
norms-iron-works.tripod.com
Old 11-29-2009, 08:53 PM
Professor, it's Denny "from the OTHER site". I was a little confused about your tecumsehs. You list the 49 as 3.5 hp and the 98 as 6. Wondering where you got those numbers. My 49 is rated as 2 and the 98 is 3.5. Might explain the bogging under power.
Have to agree, the 98cc is a pretty nice old dependabe engine.
smiley was the best I could do. :>)
Old 11-29-2009, 09:10 PM
professor's Avatar
Norm- I clicked on the wrong message that came up on my other computer. It was a trojan? and killed it's usefulness for now. So I'm on my wife's little notebook and I can't figure out HOW to get the pics from it into Photobucket! The thing uses Linex, not windows. When I get back to work I can do it.
Denny- great to see you here! That handle is a doozie.
Anyway, I know the big one is 6 hp because that is what Toro rated it (right on the designation of one of the blowers (and it ACTS like it has that much power -both on the blower and on that bike I did).
The little one, I grabbed 3 hp because I think I found it on the web. And it is 1/2 of the big one.
I just bought another Toro for $50-a 620 as a motor back-up. Nice unit, works great, but these are not too good in Buffalo- mankillers when you get a lot of snow. Driving them into hard-pack. Can't stahl them though- they really got 6 hp.
Old 11-29-2009, 09:20 PM
Hmmm, I will say that mine are pretty snarly in a two stroke sort of way too. Just went by vendors ratings. Of course that was governed to 4400 rpm if I remember right.
Handle is wood butcher with no vowels.....wood butcher as in carpenter/construction. :>) I've used that on some building sites. Self explanatory to people who know, and mysterious to those who don't. :>)
Old 11-29-2009, 09:47 PM
corgi1's Avatar
corgi1 corgi1 is offline
E-bike motor is a 450 Watt?
Old 11-29-2009, 10:17 PM
professor's Avatar
This particular bike is home made and using a little scooter motor of 250watts. E-bikes use a variety of outputs. Currie uses 450w motors, I think. The 250 seems fine to me, but is geared down, geared up to go 15-20 mph would NEED a 450 watt motor.
Old 12-01-2009, 11:28 AM
professor's Avatar
Here are a couple of pics of the drive motor set-up-
It looks a bit busy with 3 idlers, but two of them keep the chain off the frame.
The motor can be replaced with a 450w later on since it is the same diameter, just longer and the mount / clamp lets the motor be slid into position for chain algnment before being clamped down.
The entire bracket that holds the motor and jackshaft unbolts, leaving that part of the frame unmolested except for the raised shock mount hole.
The back triangle has a couple of tabs welded to it for the idlers. Otherwise, the frame is stock and can be stripped of everything and be a normal bike again.
Since this is going well, "normal" likely will not happen.
