| 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! |
11-29-2009, 09:03 AM
Is it Economical to Use Synthetic?
I've been using Amsoil Saber Pro for my HappyTime engines for over a year now. I understand that there is less wear and less smoke than using natural oil, however I've begun to wonder whether it's economical to use synthetic oil in these cheap engines.
Replacement pistons, rings, and cylinders are cheap. So if I used cheap motor oil maybe it would be cheaper over the lifespan of the parts than if I were continue using expensive synthetics.
Any thoughts?
Reason: Grammar
11-29-2009, 10:27 AM
Re: Is it Economical to Use Synthetic?
It's probably a few more dollars cheaper to run conventional, but the long run not a huge dollar amount.
11-29-2009, 09:39 PM
I run lucus semi synthetic,opti-2,and other synthetic oils and there is no large cost difference....Stick with the synthetic unless you enjoy tearing these engines down and rebuilding them....
John-John
IF I CANT FIX IT,IT ISN'T BROKEN!....ummmmmmm so I thought....
11-29-2009, 11:11 PM
just a question here wut happens if you just use regular motor oil like 5/30 or 10/30 besides the die not being there wut else is missing in the oil? still lubricates and burns no?
11-30-2009, 03:03 AM
According to the public at large:
Originally Posted by wikipedia
Comparing regular lubricating oil with two stroke oil, the relevant difference is that two stroke oil must have a much lower ash content. This is required to minimize deposits that tend to form if ash is present in the oil which is burned in the engine's combustion chamber.
That, and a difference in viscosity (and, I'm sure, other chemical properties that I have no idea about).
See: here
11-30-2009, 08:44 AM
I spend about 1/4 as much as my buddy who uses synthetic. Partly because he uses it at 25:1 and I use Walmart marine oil at 50:1.
Running no oil at all would be most economical except after 2 weeks the engine seized. I broke it loose and got home but... well you get the idea.
Reason: no oil
11-30-2009, 01:44 PM
I'm loving synthetic.. Not using any special stuff.. But im happy.. Runs well
I'm using Mobile Extra 2T Engine oil
There was this kid here who got an 49cc bike the china 2 stroke from a guy who was selling his used bike.. The kid ran the bike without engine oil and it locked up and he cried.. He didn't know he had to mix oil with the gas ran it full throttle everywhere without oil!
Reason: Remebered kid with bike
11-30-2009, 01:52 PM
Is it economical... no
non synthetic oil is perfectly fine for these engines, it fouls the plugs a little and causes the engine to run a little hotter. Plugs cost less than 3 bucks to replace and ive run bikes 3000 miles on non synthetic without changing plugs.
That's all on paper, synthetic oil will improve your performance a little, starts are easier and you get less smoke. So the choice depends on how you value those things.
Personally I use a mixture of Heet, Amsoil Interceptor, Marvel Mystery Oil, and Opti 2 (even though they don't recommend mixing oils). The ratios are classified and I call it Phil's secret Stuff.
11-30-2009, 10:55 PM
I thought one of the purposes of adding the 2 stroke oil was to clean out those deposits - like as in it had some extra cleaning property or something.
11-30-2009, 10:58 PM
I just stamped it UNCLASSIFIED with big red letters!!!!Whats the ratios Phil????
John-John
| Thread Tools |
| Display Modes |
Linear Mode
