Re: Help! Loud noise when clutch is in
1 remove the cover
2 remove phillips stop screw on pressure plate
3 with hand reach around push clutch arm with hand to disengage clutch note where arm is before loosening flower nut draw a mark on the case under arm for refrence for reassembly
4 hold arm in and unscrew flower nut
5 release clutch arm lol and remove pressure plate and spring
6 now you can see the 19 mm nut loosen nut with thinwall socket impact works best here if gun n/a try to hold hub with something to loosen .... You can put a rag between the gears to lock them for an easy way to remove the nuts same thing when you go back together. the rag will bind the gears with damaging them.
7 install clutch removal tool remove clutch assy and inspect and hopefully repair
8 assemble in backwards order tighten flower nut until arm is at previous mark on case hope this helps
turnin n burnin @ PIRATE CYCLES
DUCATISTA
Reason: added use of rag, you can just lock the clutch lever on the handlebars to remove the flower nut
