Old 11-28-2009, 09:22 AM
toker_ace's Avatar
Default mega gear question.
Does a mega gear freewheel require a special derailler? I'm having problems with my derailler on a mega gear freewheel i put on. thanks
Old 11-28-2009, 10:00 AM
Electricycle's Avatar
Electricycle Electricycle is offline
Default Re: mega gear question.
The nature of Mega Range is that it has a very broad ("mega") series of sprockets, in terms of the number of teeth on each. You might have a range from a 13 tooth to as much as 32 or maybe 34 on the largest sprocket.
This means than when shifting through the range from large to small a lot of chain becomes slack. This is why you need a rear derailer with enough travel to take up and release all that slack chain.
So the answer is YES, you need a compatible der. You also need to cover the correct number of sprockets or your indexing won't work smoothly.
Old 11-28-2009, 12:26 PM
Elmo's Avatar
Elmo Elmo is offline
Smile Re: mega gear question.
You need a wide range derailer. I have a 8 cog megarange cassett on my pedal recumbent and it works flawlessy. I do not have index shifting I use barend shifters. For me they work much better than index. Maybe because I have a very long chain, 2 1/2 regular chains. My bike is a toureasy clone. Here is a link to harris cyclery with info and a range of derailers from expensive to cheap. Campagnolo, Shimano and SRAM Bicycle Rear Derailers from Harris Cyclery I woyldn't mess with the lowend ones, get the best you can afford, you will be glad you did in the long run. Hope this helps.
Elmo
Elmo
All times wasted wots not spent ridin
Old 11-28-2009, 01:04 PM
Blakenstein's Avatar
Blakenstein Blakenstein is offline
This depens on what kind of derailer you have to begin with . As long as it has the range you will be okay if you adjust it the right way. I put a mega low range sprocket on my 7 gear cassete( changed from 28 tooth to 32 tooth) and did not have to change my derailer,however I had to adjust it properly. If your original cassete is an 8 gear to begin with, you dont need to buy a new derailer. I also have an 8 gear cassete with mega low on it. I do not see any significant diference between my 7 gear and 8 gear mega range derailers . All you have to do is make the nessesary adjustments.:-/
Old 11-29-2009, 05:30 AM
42blue15 42blue15 is offline
The "MegaRange" gearing is not really any greater than normal, it was a low of 11T or 12T and a highest of 34T gearing, which was common then and now.
The "Mega Range" is an older/cheaper Shimano cassette setup that had a particularly wide jump between the largest and second-largest cogs. It looks visibly different than most other bicycle clusters and freewheels.
This Sheldon page shows them disassembling one:
The Shimano Mega 7 Freewheel
If this is what you have, then it appears that there may have been a particular derailler for it.
This Amazon page:
Amazon.com: Shimano RD-TX51 Tourney Mega Range Rear Derailleur 6/7 Speed Hanger Mount Black: Sports & Outdoors
has a (Shimano) Tourney derailler branded as "MegaRange",,,,, -and I know for a fact that all Tourney deraillers are not branded as "MegaRange".
