Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle > Whizzer Motorized Bicycles
Whizzer Motorized Bicycles Whizzer motorized bicycles are still produced today, and one of the oldest motor bikes around. Share some of your stories about this timeless classic with us today
Old 11-27-2009, 06:31 PM
bbeards2 bbeards2 is offline
Default Whizzer with a chain and sprocket
I've been thinking more and more about embarking on a new build. The style of bike I would like to build, resembles a 66s cafe racer. Before I start I was wondering if a whizzer engine could have a pulley that goes to a sprocket? Next what size gears would I need to run on the bike to achieve normal speeds considering I would be using a 20 inch wheel instead of a 26.
Thank you
Old 11-27-2009, 08:47 PM
MotorbikeMike's Avatar
MotorbikeMike MotorbikeMike is offline
Dealer
Default Re: Whizzer with a chain and sprocket
Hi I can't wait to hear how you would like to do this, the last Whizzer that I saw chain-driven used a 1937 Royal Enfield transmission, belted to the engine, and chained to the rear wheel, this gave him 3-speeds, a clutch, and a kick-starter.
What did you have in mind?
Mike
www.ezmotorbike.com www.simpsonmotorbikes.com
Home of the EZM Q-Matic Products
08 Racer and NEW Model 10 production bikes
Whizzer, Starfire, and SkyHawk
Old 11-27-2009, 09:49 PM
Um not sure i was going to try and rig it through the bottom bracket of a bicycle. Maybe have a pulley connect to a sprocket on the right side. Do you know of any place online that sells just the engine. Where can I find the one with OHV?
Old 11-28-2009, 10:52 PM
Quenton Guenther's Avatar
Quenton Guenther Quenton Guenther is offline
Dealer
Hi bbeards2,
The 1950 Whizzer sportsman had 20" wheels [I have one], and the clutch ratio was different than the 26" Whizzer. The ratio from the clutch is 4.43 X 1 on the 26" version, and 3.85 X 1 on the 20" Whizzer sportsman. Just duplicate the ratios with chain sprockets and it will work, I.E. wheel sprocket = 50 tooth and the drive sprocket = 13 for a final ratio of 3.846 X 1 [close to 3.85 X 1].
The overhead Whizzer conversion is about $1200.00 if you have the motor to convert. The average price of a Whizzer motor is approx. $700.00, making the total cost just under $2000.00 [counting shipping expenses].
The OHV motor is taller than the stock motor and will require frame modification in most cases.
The conversion kit is available from
70MPH WHIZZER BICYCLE!
Have fun,
