Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Mounting Techniques
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Old 11-27-2009, 11:37 AM
rkorson4209's Avatar
rkorson4209 rkorson4209 is offline
Default Clamshell adapters
Yea I just got my clamshell adapters from Thats Dax. I was wondering if anyone has used these, and how exactly they work. I kinda have a idea but am prolly totaly wrong. Please anyone let me know
Old 11-27-2009, 12:17 PM
2door's Avatar
2door 2door is offline
Default Re: Clamshell adapters
I'm not sure what you mean by "Clamshell Adapter". Typically that refers to a rear hub adapter to mount the sprocket to the hub as opposed to the "rag joint" or rubber donut style of sprocket mount. I don't believe dax sells clamshell adapters because the machining is very size critical and every hub is different. The clamshell adapters I've seen are all made and sold by machine shops. Here's an example: SPROCKET ADAPTER Can you be more precise?
Old 11-27-2009, 12:44 PM
No Clam shell adapters for large frames from dax ENGINE_KIT_PARTS_PAGE_4
Old 11-27-2009, 01:02 PM
2door's Avatar
Sorry for the misunderstanding. I've not personally used those but maybe someone here has and will reply. In the interim here is a lot of good information regarding your situation. http://motorbicycling.com/f6/oversiz...lved-6427.html
Old 11-27-2009, 01:08 PM
Thank you tom for your help, I guess I should have been more descriptive.
