Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 11-27-2009, 06:50 AM
wog383's Avatar
wog383 wog383 is offline
Default Ceramic pistons
Does ceramic coated piston prolong motor life?
I have seen people reccommend it for two strokes air cooled engines...
Old 11-27-2009, 10:53 AM
1 low 64's Avatar
1 low 64 1 low 64 is offline
Thumbs up Re: Ceramic pistons
It can help in most engines. The ceramic on top will stop “hot spotting” and the antifriction coating on the side skirts will definitely help during break in. Don’t fall for buying one for $70+ you can take your piston to a powder coater and they can do it for about $20 same process and coatings just cheaper. I’m assuming since you in Australia your thinking of buying the pistons Rocksolid provides. I guess based on coating costs there it could be a deal, but definitely check before spending 3 times the cash.
Never think of what you can’t do.
Old 11-27-2009, 09:40 PM
wog383's Avatar
Default Re: Ceramic pistons
Do powder coaters do ceramic coating or do I need to find a company that does thermal coating for like heavy industries?
Old 11-27-2009, 09:54 PM
1 low 64's Avatar
Lightbulb Re: Ceramic pistons
Almost all powder coaters do ceramic coating since both types require almost the exact same tooling. If you start calling around make sure they know how small the piston is, otherwise in most cases they flat rate around $70 each, for larger (car type) pistons. I took in 10 pistons at once and got a better rate of $12 each, and sorry their all spoken for.
