Old 11-26-2009, 04:09 PM
dedpan dedpan is offline
Default HT Maintenance Right side gears
Hi,
Dumb question from a n00b.
The maintenance documentation says to apply grease to gear train. Where do I find the gear train and what does it look like?
Thanks to everyone who posts here as I found these forums an invaluable resource.
Old 11-26-2009, 05:43 PM
Bikeguy Joe's Avatar
Default Re: HT Maintenance Right side gears
Remove the right side cover and you'll see two gears. Use a small amount of grease to cover the teeth. Don't over do it!
Old 11-26-2009, 06:39 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I have found that a very small amount of grease to the tiny bearings in the clutch is even more important!
Old 11-26-2009, 07:03 PM
spit_fire's Avatar
spit_fire spit_fire is offline
how do you recomend taking apart the clutch without loosing all the bearings and also how do i start a new thread or post?
Old 11-26-2009, 08:48 PM
2door's Avatar
2door 2door is offline
Spit Fire,
First of all I wouldn't recommend that you take the clutch apart. Why would you do that?
If you want to start a new thread, new subject, select the appropriate heading from the forum's home page. There are several to choose from including the 'Introduce Yourself' General Discussion', 'Pictures and Videos' and others. If you have a technical question about a 2 stroke motor go to that heading then click on the sprocket icon at the top of the page where it says "New Thread" You can then begin a new discussion of your question. It's probable that whatever question you have has been asked and answered numerous times. We suggest using the 'search' feature to keep from posting duplicate questions. The chances are that you will find the answer you're looking for by reading a little. Welcome to the forum and glad you've joined us. We're all here to help if you have problems.
Old 11-29-2009, 03:23 AM
DonnnN's Avatar
DonnnN DonnnN is offline
You'll see two gears on the right side off your engine.. Apply very little grease onto both the small and big gear.. VERY CAREFULLY apply it.. You don't wanna get grease all over the clutch pucks..
And why would you want to remove the whole clutch lol?
Old 11-29-2009, 06:30 PM
spit_fire's Avatar
venice mentioned greasing the liltle ballbearings in the clutch wouldent you have to take it all apart to get to the lil guyz to grease them?
Old 11-30-2009, 06:44 AM
DonnnN's Avatar
Yep...
http://motorbicycling.com/f4/bicycle...lutch-222.html
