Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 11-25-2009, 11:11 AM
mifletz mifletz is offline
Default Checking Robin valve clearance procedure
Can valve clearance be checked oneself, or does it need a mechanic?
The "instruction manual" says every 200 hours. No reference to checking it after the 20 hour break-in. Is it necessary to check it after the first 20 hours?
Is there anywhere on the internet explaining (ie "service manual") exactly
how to do it on a Robin 35?
What are the symptoms of incorrect valve clearance?
Old 11-25-2009, 11:18 AM
ocscully ocscully is offline
Default Re: Checking Robin valve clearance procedure
The Service manual is available from Robin America Here is a Link to the pdf http://www.robinamerica.com/media/ma...9394630000.pdf
ocscully
Old 11-25-2009, 11:54 AM
Ta very much!
