Hi
I did some mods, repaired a broken thread with a heli coil, i did some port matching in the intake, i think it's great.
But i have one problem: until i get 34 or 35km/h, the bike have the typic sound of 2 stroke. Up than 35km/h starts to 4 stroking
I have a NGK B7HS, stock carb, base gasket is aluminium papper (0.05mm or so), head gasket stock, and a little skirt mod in the piston.
Can be the carburetor that restricts the air and starts the 4 stroking?
Just for note:
The 4 stroking in high rpm is caused by too much fuel in the mixture (as Joe, Norman and Riding rich said), so you should lean it out. Smaller main jet, or moving the c-clip to the first or second position
Problem solved
