Old 11-24-2009, 09:42 PM
MattLGiberson MattLGiberson is offline
Default No Gas ?!?!?
Ok, so I finally finished getting my newest bike all set up and it won't start. I get gas into the bowl but no gas into the cylinder. It's a brand new carb and I can't understand why I'm not getting and gas. Any ideas ?
Old 11-24-2009, 10:01 PM
marts1 marts1 is offline
Default Re: No Gas ?!?!?
How do you know its not getting gas? Maybe its an electrical problem.
Old 11-24-2009, 10:20 PM
I tested it for spark....it sparks fine. When I take out the spark plug is bone dry.
Old 11-24-2009, 10:58 PM
spit_fire's Avatar
spit_fire spit_fire is offline
did you check that your jet isint somehow plugged? i seem to have my carbs play games with me all the time and by the time i take them appart to se wats wrong with them to find nothing wrong i put it back together and it just so happens to work just fine after (funny how that works)
Old 11-25-2009, 10:18 AM
Bikeguy Joe's Avatar
Check for the dreaded air leaks at the intake to cylinder junction.
Check your jet, it may be loose or sitting in the bottom of the float bowl.
Old 11-25-2009, 11:34 AM
Really is amazing how often this works.
Old 11-28-2009, 11:16 AM
Thanks guys,
I'll tear it apart, throw it back together and hope for the best
Old 11-28-2009, 03:00 PM
freewheeling frank freewheeling frank is offline
try throwing a little gas right down the tube i use an eyedropper to do this but a peice of tubing will work, dip it in gas and put yer finger over the end
