Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 11-20-2009, 03:06 AM
bryanedp9 bryanedp9 is offline
Default What can I fit in a stingray?
Hi guys,
I've got a newer (maybe '04) OCC type Schwinn Stingray with the seating tube cut totally from the frame. I don't think this has really effected stability.
What I need to know, though, is what is the largest and best 4 stroke engine I could fit into this thing? I'm not sure exactly how much room I have to work with, but I'd like to think I could fit maybe up to a 125 dirtbike engine in there, albeit a little uncomfortably.
So if you know anything, as I'm new to this, what all should I do/what can I do to make this bike run strong and proper?
Any advice is appreciated. The goal is to go street legal and pull off the highest possible speeds. It'd be great if you guys could tell me how to switch to a disc brake system too. So many questions.
Old 11-24-2009, 02:25 PM
Default Re: What can I fit in a stingray?
anybody at all?
Old 11-24-2009, 03:11 PM
troyboy's Avatar
troyboy troyboy is offline
Your East Coast Gasbike Connection
Originally Posted by bryanedp9 View Post
anybody at all?
Talk to flybytaco.. He does a lot of these bikes. 2 strokes though. be sure to check out the sprocket adapters and use a 36 tooth sprocket if you want any type of speed out of that 20 inch rear tire. I have one left in stock.
Good luck
Justin
Grubee Skyhawk Gas engine kit
