Old 11-19-2009, 09:13 PM
Kevron99's Avatar
Kevron99 Kevron99 is offline
Default How to eliminate clutch noise
Hello Forum Members,
I just want to know how to eliminate clutch noise? or is it noise coming from clutch? if not what is it?
Please see the Video,
YouTube - Felt Bike first install
Old 11-19-2009, 10:00 PM
2door's Avatar
2door 2door is offline
Default Re: How to eliminate clutch noise
Kev,
Sorry to say, but it sounds like almost every 2 stroke I've ever heard. Videos always seem to distort the sound, maybe the mic in the camera, but I think what you're talking about is that rattly sound along with the exhaust/intake noise. The primary gears which always rotate are not the precision cut that we'd all like to see so they do produce some weird noises. A small dab of grease on them will help but for the most part the clutch noise is normal. Some guys have had luck with gluing a sheet of foam rubber to the outside surface of the clutch cover; I made a thick rubber gasket from 'O' ring material which helped cut down on the echo through the aluminum cover. My advice? Get on that good looking bike, ride it and try to ignore the built-in noise that is inherent to these little engines. Sweet looking ride, by the way. How's it run?
Old 11-19-2009, 10:09 PM
Cabinfever1977's Avatar
put small pieces of rubber hose inbetween ever other fin on your engine,dont forget the top fins and check to see if your clutch is rubbing on your clutch cover and if it is u can add another gasket or 2 to space the cover away from the clutch.
besides that, you have a very sweet lookin ride,very nice job.
Old 11-19-2009, 10:13 PM
FileStyle's Avatar
I made my own using 3/16" rubber cut into the shape of my cover and then using silicone to apply with a heavy weight on it overnight. all is good!
FileStyleCycles
Old 11-20-2009, 03:15 AM
BarelyAWake's Avatar
I cheated and sprayed the inside of the cover with a coupla coats of rubberized undercoating, that combined with a light touch of grease to the gears seemed to help cut the noise down a bit.
Old 11-20-2009, 08:18 AM
Bikeguy Joe's Avatar
The cure for the gear noise is to replace them with something that is not straight cut and hewn from stone.
Other than that, enjoy it as part of the experience, and you can always tell people it's got a blower in there somewhere.
