Old 11-19-2009, 04:53 PM
Bikewithamotor's Avatar
Bikewithamotor Bikewithamotor is offline
Default 9 tooth drive sprocket (or less?)
Hi Guys...little dilemma, you know how the sprockets that the engine kit comes with are a little slow with hills...(44 tooth rear sprocket, 10 tooth drive sprocket)
So....heres what I am wondering...
If I replace the 10 tooth drive sprocket for a 9 tooth,
how much easier could I go up hills?
would it make much of a difference?
Is it worth it to buy it?
Thanks loads
Old 11-19-2009, 05:42 PM
2door's Avatar
2door 2door is offline
Default Re: 9 tooth drive sprocket (or less?)
I believe this question was asked and answered. It would be much easier to replace the rear sprocket with a larger one than to locate and replace the engine drive sprocket. Hill climbing ability is increased with a larger rear sprocket which are readily available from numerous sources. Standard sprockets supplied with most kits are in the 40 to 44 tooth range and are good general purpose sprockets. Moving up to a 48 to 54 will give you better hill climbing performance but will hurt your top end speed as well as allowing the engine to run at higher RPMs. You might find a smaller sprocket for the engine but it is not a standard size bore and might require some very expensive machine work to get it to fit and then you're restricted by reducing the tooth count(sprocket diameter) by only a couple of teeth which won't help you that much.
Old 11-19-2009, 06:23 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I concur with 2door... it's much easier to find a larger rear sprocket!!
Old 11-19-2009, 07:34 PM
Banned
I would like to know where you have found a 9T to purchase?
Jim
Old 11-19-2009, 07:39 PM
Thumbs up Re: 9 tooth drive sprocket (or less?)
The 9 tooth is here:
Sick Bike Parts
Dont worry if it is a different size than your chain...it is just a little thinner so your chain will still fit on it just fine!
Old 11-19-2009, 07:53 PM
Banned
Sick Bike Parts
O.K. I didn't realize you were talking about shift kit stuff...I thought you were talking about a 9T replacement sprocket for the 2-cycle In-frame engine.
Jim
Old 11-19-2009, 09:40 PM
2door's Avatar
Jim
Me too. Sorry for the misleading but we had no idea what you were working with from your question.
Old 11-19-2009, 10:17 PM
NEAT TIMES's Avatar
NEAT TIMES NEAT TIMES is offline
He May Think That Sprocket Fits The Motor! If He Had A Shift Kit He Would Use The Gears For Hills. That Sprocket Will Not Fit The Engine. It Is For The Jackshaft. Hope This Helps You. As The Guys Stated, Changing The Rear Sprocket Is Best. Imho. Ron
PUMP YOUR BRAKES HAVE TO LOVE WINDOWS & THE INTERNET
NEVER BEAT ON IT, GET A BIGGER HAMMER
"A MAN WHO SAY`S IT CANNOT BE DONE SHOULD NOT INTERRUPT A MAN DOING IT"
Old 11-20-2009, 05:56 PM
Pablo's Avatar
Pablo Pablo is offline
Sick Bike Parts
Sorry that is only for our Shift Kit or someone with a 5/8" shaft project. "This replaces the 10 tooth shift kit sprocket and is standard BMX chain width." and it will not fit on the engine.
