Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 11-17-2009, 11:12 PM
DVBikes DVBikes is offline
Banned
Default Weird Vibrations
i have fine rpm on low and high power bands but my mid sounds weird and the bike vibrates and sound like my motor is gonna explode lol and mr speed is fckd so idk waht to do rebulit carb last night just tighted clutch and put a new cable in. 32:1 mix way past break in. Maybe my bearings are scrwd kinda like my skate board bearings are busted but are good only at speeds its kinda doin the same thing. hope you can help me
Old 11-17-2009, 11:31 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: Weird Vibrations
did your engine start to vibrate just recently? When just one motor mount bolt breaks or comes loose it will shake your teeth out.
if its did the vibs since new then only thing you can do is try to balance the crank or check the engine bearings they could be going bad.
norms-iron-works.tripod.com
Old 11-17-2009, 11:40 PM
Banned
yeah it has, i checked my mounts that happened once to me already. hey and was reading the topd end rebuild is the torching with stock head nuts for upgraded. and which bearings
EDIT!!!!!!!!
Ive decided ive put alot of miles on this motor and im gonna by a gasket kit from spooky, can you tell me the best upgrade bearings (hoping not the same cheap chineses and a list of which one just be changed or upgraded with. idk (maybe 600 hundred miles to 1k) thanks norm or who ever
