| High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. |
11-17-2009, 01:24 PM
carb tuning.
can someone tell me in detail as i know very little of engines how to tune my stock carb for max power output?
11-17-2009, 03:19 PM
Re: carb tuning.
Fairly simple.
Look at your plug. What color is it? Oily and black? That's too rich. Move the small C clip up one notch on the needle that is in the middle of your slide.
If your plug is light gray, or white you will want to move the clip down a notch.
Check your plug after each adjustment.
That's about all there is.
11-17-2009, 04:36 PM
Re: carb tuning.
io have found that the jets on these are huge and they run rich i am at 7000+ feet i mean my house is 7g i soldered my jets snd drilled with the smallest bit i could come up with i think it was a 120 were talking the size of a old mans hair and my plug still runs on the dark side but it did make an incredible difference, as i am about 30% of origonal jet size, i run my fuel at 32/1 as with it running lean i want plenty of oil as it gets colder i will try leaning the oil up some and watch it as spring gets here
11-17-2009, 05:29 PM
Custom Builder / Dealer
Re: carb tuning.
Before you try to tune or re-jet the carb, you should finish breaking in the engine by running about 4 gallons of gas though it, & if you plan to make any changes like a smaller sprocket & expansion chamber pipe, do them all first!! Otherwise, you'll have to re-tune it again!!
11-20-2009, 09:37 PM
Re: carb tuning.
Originally Posted by Bikeguy Joe
Fairly simple.
yay!but whats a slide and where is it
11-21-2009, 04:38 AM
Re: carb tuning.
11-21-2009, 08:31 AM
Re: carb tuning.
Thank you!
11-22-2009, 12:12 PM
Re: carb tuning.
ok so i moved my c clip up one and my bike now starts harder,dies if clutch is initiated and let go of, and runs for a short while before dying,is this normal and will it subside or did i mess something up?
11-22-2009, 01:19 PM
Re: carb tuning.
The spark plug has a story to tell, you should listen to it before any of us
Fairly simple.
It could be that yer bike was just cold, as you made the mix leaner - you'd need the choke (which makes it richer) to start it and keep it runnin' till the engine warms up... and/or yer idle is just set too low...
11-22-2009, 04:00 PM
Re: carb tuning.
taking the time to take such good pics, if theres a heaven they have a seat for you , thnx. chopper
| Thread Tools |
| Display Modes |
Linear Mode
