Old 11-17-2009, 01:24 AM
kahnowerh kahnowerh is offline
Unhappy Seized Drive Sprocket
I could already feel the wind in my hair when...
Well, the chain jumped from the sprocket and got caught in the spokes.
I exclaimed things, fixed that problem (as far as I can tell) and was gifted with another.
It seems as though the drive sprocket is seized.
I could roll the bike (both with clutch in and clutch out) before my mishap.
Now the back tire's locked, regardless of clutch position.
I checked the clutch and everything looks okay.
I attempted to uncover the drive sprocket, but it seems some superhuman chinaman attached the thing, and I stripped the screw. (“—Also, Dude, ‘Chinaman’ is not the preferred nomenclature. Asian American, please.”)
So, maybe the question's a bit premature (as I can't get into where the sprocket is—yet), but I'm wondering if anyone has had the same problem or has any insight.
The weird thing, to me, is that it worked before the accident but now it doesn't.
And I'm not sure it's related to the chain jumping (but maybe when it seized the chain jumped? that doesn't make much sense to me)
Any help would be appreciated.
I've got a Dax F80.
It went together pretty smoothly for my first build...
But I think I'm going to replace all the butter-consistency bolts
Old 11-17-2009, 07:38 AM
azbill's Avatar
azbill azbill is offline
Default Re: Seized Drive Sprocket
sounds like the chain jumped off the drive sprocket
take the clutch cover off and check
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 11-17-2009, 08:24 AM
Ha... The advice I didn't want to hear last night.
I'm working on the patience thing...
Zen and the Art of Motorcycle Maintenance.
I'll let everyone know what's up after I get a bolt extractor some time late afternoon.
Until then, we can take bets...
I thought the chain had more slack previously, so I'm thinking maybe a sticky link got wedged in the small clearance area up there.
Old 11-17-2009, 10:08 AM
Venice Motor Bikes's Avatar
Venice Motor Bikes Venice Motor Bikes is online now
Custom Builder / Dealer
I concur!! (It's a easy fix!)
Old 11-17-2009, 11:33 AM
247Jude's Avatar
247Jude 247Jude is offline
I had a simular incident when my chain was too loose, it folded under the sproket cover and wedged there, try rolling it backwards with force it may pull the chain loose, and save you a little time.
Just call me Whyle E Coyote
Old 11-17-2009, 03:13 PM
Yep, I tried rolling it back and forth, with some force (increasing with my blood pressure).
I'm off to buy a new toy (bolt extractor) and I'll let ya'll know.
Thanks for the help.
Old 11-17-2009, 03:50 PM
247Jude's Avatar
Not back and forth, just back with as much force as that when it locked. The chain is train reacked under the cover and wedged between the sproket and the cover bolt housing. ( More than likely anyhow). Ackually better to take the cover off and pry it free.
Old 11-17-2009, 03:52 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
The motors are made in China by (from every video I've seen) men so Asian American would NOT be the proper nomenclature.
Old 11-17-2009, 08:54 PM
I had watched The Big Lebowski. If you're not familiar, I'd suggest you partake.
And, for some reason, Idiocracy gets better for me every time. I don't think that's supposed to happen.
Anyway, you are exactly correct, Jude.
(Sorry for the quality, cell phone.)
Anywho, my chain was far too long, I fiddled with it...
Ended up in the back streets deciding to shorten it. Told myself it was a bad idea to take off the master link only lit by streetlights (decent lighting, but not for small black-colored things).
I did it anyway. You know how that ends up.
I had to macgyver my way to a shorter chain. Luckily I had (almost) all of my tools and a poorly fitting chain-breaker (a parktools). I rigged it up to work, did some pounding, some finessing...
And now my chain actually stays on!
I'm loving my MB!
Just rode to school to pull a graphic design all-nighter...
But at least I didn't have to pedal (much).
Old 11-18-2009, 06:46 PM
Nashville Kat's Avatar
If you have any more trouble with getting the screws off- like the sprocket cover-
although they are phillips head screws, a medium flathead screwdriver will fit on them- so get a good medium sized Craftsman flathead scrwedriver (or a whole set!) with the SQUARE SHANK- designed to get a crescent wrench on, and you can turn the screwdriver with the leverage of a wrench as well.
That chinaman will probably have not gone that far...
http://thehearpe.com
