Old 11-15-2009, 08:20 PM
doubledice's Avatar
doubledice doubledice is offline
Default muffler help
Hey does anyone have advice on welding on these thin mufflers im thinking of MIG welding it on a really low setting or do you think oxyacetylene welding will look nicer? i want to make a custom pipe instead of the regular bent pipe that comes stock
Old 11-15-2009, 08:47 PM
TheOtherStyle's Avatar
TheOtherStyle TheOtherStyle is offline
Default Re: muffler help
Keep the heat down, and don't do a constant bead. Just do small tacks on opposing sides to keep the heat from building up and warping or melting through. And yes, definitely MIG instead of arc.
i'm freakin loony
www.smallengineguy.com (inventory is always being added!)
Old 11-15-2009, 10:57 PM
doubledice's Avatar
ya i was thinking of just tack welding it but what got me was some guys at my dads work did oxyacetylene on exhaust systems for cars and wondered what would work best
Old 11-15-2009, 11:01 PM
If they can do it, sweet! My skillz are not so l33t lol.
If you can do MIG, just run tacks around the way, working from side to side, on a low enough setting that it runs but doesn't blow through.
i'm freakin loony
Old 11-15-2009, 11:09 PM
spit_fire's Avatar
spit_fire spit_fire is offline
i was wondering if anybody knows of any good expansion chambers for these bikes and that preferably stay away from the inner thigh , ive seen a bunch of the bike with the expansion chamber between the legs also i was wondering how much power increase you really feal and i was wondering if there is anyone th at uses a thinner chain and if it can be done without having a custom machined sprocket at the motor thats the one that im more concerned with
Old 11-16-2009, 03:30 AM
BarelyAWake's Avatar
I use the SBP expansion chamber and I'm quite pleased with it http://motorbicycling.com/f3/skeptic...ipe-11282.html - but it does entail a bit of setup, Spooky Tooth has one that you can just bolt on and go, but I've not had one http://motorbicycling.com/f4/spooky-...ion-12731.html
As for a "thinner" chain I've heard people talkin' bout using a good BMX chain...
Old 11-16-2009, 08:09 PM
Tim_B_172's Avatar
Tim_B_172 Tim_B_172 is offline
I've welded on my exhaust system with a flux core welder. It's like MIG without the gas. The welder I used has High and Low settings, I always use low. It doesn't make the cleanest weld in the world, but it does the job.
Old 11-16-2009, 08:40 PM
doubledice's Avatar
ya iv used flux core, it takes some practice on that
Old 11-17-2009, 12:51 PM
noco noco is offline
id recomend using the torch and a coat hanger just like a cars exhaust...it looks nicer and it is easier than a mig...get it cherry red and melt the hanger in
