Old 11-12-2009, 11:06 PM
Motor Boys's Avatar
Motor Boys Motor Boys is offline
Default Trying a new carb!
I just picked up a supply of pocket bike carbs, to try out on my pk80 engine and I was wondering if anyone out there had tried this and how was the preformance? I have it mounted after making a bigger cable, tried it out and the stupid carb has some sort of choke lock on it! Any ways I gotter figured out you kind of pull it forward and it releases. So anyone done this and howed it work out?
Thanks
Great Deals, On Great Engines and Parts www.80ccmotorboys.com
Old 11-13-2009, 03:59 PM
Rockenstein Rockenstein is offline
Default Re: Trying a new carb!
When you mention the choke lock I'm thinking you maybe got the 14mm Dellorto SHA copies? If so the choke should also unlock if you quickly crack the throttle open fully.
On a stock 2 port PK80 I'd say the 14mm SHA would be about right although with the stock intake it might not as the intake's ID is pretty small in comparison to the carb's bore...that alone might make it a bear to get jetted right. Add a nice manifold with an ID that matches the carb, a decent tuned pipe on the other end a tight squish setting and I bet you'd see some nice gains and actually have a power band that you can feel. If you have access to a small torch or even a welding rig of some kind I'd seriously consider fab'ing up a manifold for your experiment.
I have a Chinese Walbro copy that I bought from Tsunami Bike in Hamilton, not sure of the model# Walbro it copies but it's about a 15mm bore. I've not used it yet but I'm thinking it's going to find a home this winter on my Riff Raff build.
Old 11-13-2009, 05:01 PM
Motor Boys's Avatar
It Thanks The ones I got are rugong stamped, and they fit the intake nice and tight. I will try a tuned pipe aswell and see how she goes. I do have a welder, so I may try to fab a pipe any sugestions?
