Old 11-06-2009, 12:07 PM
gian gian is offline
Default spark plug gap
is there anyone who could help me to find the correct spark plug gap, i dont have tools for measuring the gap ,maybe i could use any cards but i dont know what are their thickness
Old 11-06-2009, 01:32 PM
Venice Motor Bikes's Avatar
Venice Motor Bikes Venice Motor Bikes is online now
Custom Builder / Dealer
Default Re: spark plug gap
Some people run the gap small (.024 - .028), But I run mine @ .030
Old 11-06-2009, 01:38 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
i run mine at .30, too. there's no accurate way to measure without a gapper or some feeler guages.
you can walk into any auto parts store and they usually have a candy jar full of plug gapper wheels on the counter. they're like a buck or 2.
Old 11-06-2009, 01:51 PM
Pablo's Avatar
Pablo Pablo is offline
Real cheap. .99$
I find larger gap doesn't add a thing. 0.020-.025" is fine. Norm runs around 0.015".
Old 11-06-2009, 02:02 PM
I haven't seen any real performance difference in small or big gap on these engines either...
From what I know, a smaller gap is suppossed to be better for higher RPM's & a bigger gap is better for low RPM & idle quality.
I just run mine on the big side, (but not too big) because I figure a bigger spark spark equals a better burn...
Old 11-06-2009, 03:35 PM
BarelyAWake's Avatar
Another .030 here... I dunno why, it just is.
Old 11-06-2009, 11:32 PM
GearNut's Avatar
GearNut GearNut is offline
A typical business card or matchbook outer cardboard is about 0.018" That'll get you close enough if you fit it a teensy bit loose.
Old 11-09-2009, 08:24 AM
xlite xlite is offline
There is a significant difference between small and large gap. In dyno testing large gap gives measureable increase in performance (saw this myself) but fouls easier. Small gap runs better with fouled plug but slightly less power.
When plug gets dirty and misfires I've got home by knocking the gap down. Also had to decrease gap during experiments with light on the white wire.
I use any old piece of Harbor Freight stainless safety wire (.031") laying around to gap mine.
Old 11-09-2009, 09:18 AM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
here is some thing I do to the china spark plugs and I run a gap of 0.017 to 0.020 on them.
I was told abut this by a guy who does chain saw racing says it uncovers the flame Kernel for better combustion does it work? Beats me I do it for fun.
If you guys want to build a dyno testing system there is plans on the net to make one using a hyd.pump and assorted material I think it was on a racing kart forum I've see it and down loaded the plans years ago but never did make it. I guess I should have. I'll try to do some looking and see if I can find a link you guys might be able to do the same if your wanting info on a homemade dyno.
norms-iron-works.tripod.com
