Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 11-05-2009, 02:02 PM
floatingphotog floatingphotog is offline
Default chain drive gearbox
Was pokin around E-Bay and found this 4-cycle w/chain drive gearbox. Anybody use this kit? Here is the url
4 strok 49CC MOTORIZED BICYCLE ENGINE KIT GAS MOTOR EPA - eBay (item 290337483935 end time Dec-04-09 08:39:35 PST)
Let me hear what you all gotta say bout it. Thanks
Terry
Old 11-05-2009, 02:38 PM
aero07's Avatar
aero07 aero07 is offline
Default Re: chain drive gearbox
Looks like the same gear box on some pocket bikes. Cheap.
Old 11-06-2009, 09:09 AM
civlized's Avatar
civlized civlized is offline
I would like to give it a try. I think I will order one to see how different it is.
Old 11-06-2009, 12:51 PM
Hi Civilized, Today I was looking thru the other big forum (motoredbikes.com) and I found that gearbox. This is the thread New HS motor very rough idle under 4-stoke. The consencis there was that the gear reduction was't enough. Rear gear not big enough. Also, there was sooooo much slop in the chain, that an idler needed to be fabricated and fitted in. Scared me!
Terry
Old 11-06-2009, 12:56 PM
civlized's Avatar
Thanks for the info. I found access to one for free off of a two cycle dirt bike. I'm gonna take a look at it next week to see if I can use it or not. I would much rather tinker for free as opposed to buying a new kit. Thanks again.
Old 11-06-2009, 12:58 PM
civlized's Avatar
This must be the new hoot GB's! Complete waste of time and money, so far.
Old 11-06-2009, 01:41 PM
Wow!! That sounds like u might even get a real tranny out of that
Old 11-06-2009, 02:28 PM
Quenton Guenther's Avatar
Quenton Guenther Quenton Guenther is offline
Dealer
Current information supplied by testers yeilded the folllowing.......
Major primary chain stretch [very poor quality chain], damaged chain sprockets, cracked cases due to stress of the drive shaft [way too long without support], noisy , incorrect drive ratios. Clutch issues including mis-alignment of shoes to hub.
Motor is good quality. However due to design can not accept many of the current production drive systems [EZM, Grubee, earlier Hoot, etc].
Hope this information is helpful.
Have fun,
Old 11-06-2009, 03:25 PM
civlized's Avatar
Thanks Quenton. That sounds like enough info for me. You know what they say about polishing a turd. I have had my fill of that task.
