| Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. |
11-04-2009, 04:30 AM
My bike died!
well my bike was running fine for a while til i noticed a crack in the side of my ignition coil from over tightening it. After a while of rain and moisture from sitting out over night ( i kept it covered with a tarp most of the time), my motor started acting funny then quit running. i bought a new igniton coil butit didnt fix the problem. I pulled my spark plug out connected it to the wire and grounded it to the cylinder head and it seems like it isnt spark as much as it should. i opened my cover to the magnetos and it had a brown residue ver the coil inside of it. anyways, my motor kit was the RAW 80/66cc and it lasted about 2 months of some rather hard riding and the occational abuse of burnouts on smooth wet cement. also it seems to kind of catch every 3/4 turns of my back wheel, i theck my brake axle and wheel they are all in good condition, and no abnormal wear or rubbing anywher im fairly certain its something inside the motor.
here how i ran it
32:1 (4oz. per gallon)
i ride full throotle alot but i back offregularly and blow it out/ purge exhaust by clutching it and wrapping it a few times.
also whats the difference of a slant/ angle firehead versus stock, aside from angling plug. does it improve performance??
PS- I just ordered an 80/66cc BGF kit with slant head and pull start off ebay. are those kits better quality then the RAW kits??
11-04-2009, 07:55 AM
Re: My bike died!
Try a new plug, and check you chain for straightness. Don't over tighten the chain either 3/4" of freeplay is good.
11-05-2009, 11:16 PM
Re: My bike died!
i tried a new plug is fire some but i dont think its right. and its a brand new CDI box
11-05-2009, 11:33 PM
Re: My bike died!
you mentioned a brown residue in your magneto... it could be that your oil seals are damaged or popped out. Check also the oil seal on the gear side...
Regardless if it's left or wrong, the opposite is always right.
Caution: This hobby is habit forming.
11-07-2009, 12:47 AM
Re: My bike died!
well, I'm not really interested in fixing it ATM, as it was the bottom of the barrel brand and it put it through some tough times. But I just bought a BOy go fast motor and i was wondering if those are a bit more durable and better made. i found a slant head kit with pull start for $93 + free shipping so....
11-07-2009, 12:35 PM
Re: My bike died!
From what most people I have talked to say the Raw engine is better than BGF....I have a BGF replacement engine on my bike now and it has 250 miles on it and running good(other than my top speed is 25MPH) so I cant say anything bad about them....I bought 2 Raw engine kits that came in last week and havent put one on a bike yet so I dont have anything positive or negative to say about them....I will know soon enough when I mount one on a new cranbrook in the next few weeks....
From what I understand is that Raw has been around longer than anyone other than Grubee and all come out of the same plant....
John-John
P.S If im not mistaken you will need a wider crank becouse of how far the pulll start sticks out....
IF I CANT FIX IT,IT ISN'T BROKEN!....ummmmmmm so I thought....
11-08-2009, 01:08 AM
Re: My bike died!
John-John
well i can tell you about the RAW kit i got.... The stock clutch cable sux. the sheath kinked and cause cable to snap. the flanges on the carb are very brittle, the intake manifold and exhaust both had a lip that consticts air flow.
11-08-2009, 02:55 AM
Re: My bike died!
lol - that sounds 'bout the same as every chinagirl made! Don't sweat it though at least ya know what yer gettin' into
Actually, the clutch cable is a lil odd - while my "generic" kit did have a wimpy cable it's held up fine, the "Grubee" kit's cable seems about right - even slightly overkill. Stuff like that is easy to upgrade tho, and the sloppy welds & casting flash is jus a few minutes w/a Dremel
11-08-2009, 09:10 AM
Re: My bike died!
mine oxidized quick too. Does anyone know how well the painted black ones hold up to the heat??? is it decent paint? will i have cooling issues?
11-08-2009, 07:19 PM
Re: My bike died!
You can do a better black paint job yourself with a spray can.
Part of the reason the "natural" finish engine look so bad after little use is because of the coating of cosmolene or whatever it is they are shipped with.
I clean the whole engine with brake cleaner prior to installation, and they seem to stay pretty good looking.
| Thread Tools |
| Display Modes |
Linear Mode
