Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 06-01-2008, 02:53 AM
spad4me's Avatar
spad4me spad4me is offline
Default Two-Stroke Tuner's Handbook link
Port and polish
You know you want to.
Gordon Jenning's Archivek
From the site.
An anonymous donor has provided the Two-Stroke Handbook in Word so it is very usable and printable! 2-stroke-guide_r2.zip. Thanks LM!
Or PDF of scanned book if that is more convenient, 2stroketunershandbook.pdf
Articles
aspirin_takers.pdf
crankcase_volume.pdf
delivery_ratio.pdf
do you really.pdf
higher compression.pdf
l-rings.pdf
oilpremix.pdf
ossatuningspdf
race_preparation.pdf
sachsengine.pdf
some_development.pdf
topend_rebuild.pdf
webco_power Hodoka.pdf
I would like to pose a question.
A thinner head gasket with a modified or removed base gasket improves power.
How about a double base gasket and seal the cylinder head with permatex only.
As long as the piston doesn't hit the head.
also another good link Performance tuning by Graham Bell
http://www.kreidler.nl/artikelen/per...raham-bell.pdf
Old 06-01-2008, 11:56 AM
paul's Avatar
paul paul is online now
Administrator
Default Re: Two-Stroke Tuner's Handbook link
nice find! i put a copy in the classic posts area. as far as you question i really am not sure. norman would be the one to ask and he should be back from vacation soon
Old 06-01-2008, 08:24 PM
Bikeguy Joe's Avatar
You can play with port timing a little by juggling head and base gaskets.
I don't know that permatex would seal the head though.
Old 06-01-2008, 09:41 PM
spad4me's Avatar
Thanks for the information. I am looking for easy , and inexpensive piston ported low compression tuning tips.
Old 06-02-2008, 06:11 AM
Match up the port/gasket/exhaust.
Dial in the carb as best as you can.
I believe you can lose one of the two base gaskets if your bicycle motor came with two like mine did.
Make sure the head stays torqued properly.
After that, it's time for some porting and a few other two stroke tuners tricks.
Mix well and enjoy responsibly.
Old 06-02-2008, 07:02 AM
Pablo's Avatar
Pablo Pablo is offline
Cool - I'll take a read on that. Thanks!!!
