Old 11-03-2009, 01:04 PM
2door's Avatar
2door 2door is offline
Default Re: The *BEST* Solution for "THE" tensioner/pulley
Very Very nice. Its less welding and more eye pleasing than mine. Good work my man. Thanks for sharing.
If I'm seeing this correctly, (master link just leaving rear sprocket?) I'm not being picky here but you should really turn the clip on your master link around. The closed end should enter the engine sprocket first. The way you have it, it can get kicked off by interference with the sprocket/ clutch actuator case. Just an observation that might prevent a chain loss. If I'm seeing it right.
Old 11-03-2009, 01:10 PM
Prasinos's Avatar
Prasinos Prasinos is offline
Having no pensioner would be nice no doubt but don't forget that no matter how tight your chain is it still may need a tensioner. Ive built 10 bikes now and some have output sprockets that are almost a half inch out of line with the rear sprocket and the tensioner fixes this. It would be a real pain in the butt to fix this problem without it. For the record, i like having a spring tensioner but i have no problem with the stock one. Besides having to bend some to get them to line up there are little to no problems once set up.
Old 11-03-2009, 01:21 PM
sportscarpat's Avatar
sportscarpat sportscarpat is offline
No tensioner would be nice and I could have done that, but what I found in my application is that the chain would rub the frame chain stay. By lifting the chain in this area it allows the chain to clear the frame. Sometimes the bike tells you what it needs.
Old 11-03-2009, 04:23 PM
Dan's Avatar
Dan Dan is offline
Staff
Originally Posted by sportscarpat View Post
New around here and my first attempt at a motor bike and my solution to the idler sprocket. I will try to post a picture. Here goes. Well, the attachment worked. I used a #41 Diamond brand chain, an 18 tooth idler sprocket with bearing insert, tig welded a small laser cut tab to the bottom of my frame. The weld on tab is slotted to corectly adjust chain tension. Works great and have had absolutely zero problems.
Very cool! Really like the looks and function. Purty work Sport.
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 11-03-2009, 04:39 PM
Nashville Kat's Avatar
RELIGIOUS FERVOR?!!!
You want some religious fervor? I'll give you some religious fervor!
Question: Why are Mormons buried EIGHT feet underground?
Answer: The two extra feet is for the bicycle.
Prasinos says above: "Having no pensioner would be nice..." Must be a Republican. Ya
Old 11-03-2009, 04:43 PM
Dan's Avatar
Dan Dan is offline
Staff
Dang Tom! With glasses on and magnifying glass, (no kidding) still am not sure but think your right. Great catch.
Chain coming apart is a really bad thing at speed. I really can't see if it is reversed though Sportcarpat.
Tom makes fun of me for remembering it as a lil rocket propelling the chain. I remember the ball bearing chain cages on the bottom bracket by; protect your balls, face 'em inward" (LOL, I are slow and actually need these weird lil ways to remember stuff)
Old 11-03-2009, 05:05 PM
BarelyAWake's Avatar
I bet he's got a 5' monitor... geez
Good eye Tom lol
Old 11-03-2009, 06:02 PM
bandito bandito is offline
With IE8 you can magnify up to 400x by 1 click on the bottom of the screen.
Old 11-03-2009, 09:16 PM
Dan's Avatar
Dan Dan is offline
Staff
my best bud is blind and uses "zoomtext" doubt he would have cought that. Amazing Tom
Old 11-03-2009, 11:16 PM
2door's Avatar
Photo Shop...I can ANYTHING with Photo Shop. Actually I saw his master link on my old 80s vintage monitor at work. I downloaded that pic to PS and enlarged, enhanced it and used a shapening filter. It looks like its backwards but I'm not absolutely positive. I'm still waiting for a reply from him to confirm.
MotorBicycling.com
