Old 11-01-2009, 06:01 PM
longhorn6 longhorn6 is offline
Post The *BEST* Solution for "THE" tensioner/pulley
GET RID OF IT !!!!!!!! THROW IT IN THE GARBAGE !!!!!!!!!!!! Ok, so i had sooooo many problems with my tensioner. Was also really loose still. So I brought my bike to my local bike shop and they said jus get rid of it Could it be that simple i pondered to myself?? YES IT IS !!! i took it off (or they did LOL) and we shortened the chain and (Ur technically not supposed to do this BUT I have had no problems with doing this) FORCE Fed the chain onto the sprocket.
With the end result of it riding sooooo smooth and working properly SO jus ditch the tensioner LOL THAT EASY
Old 11-01-2009, 06:27 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
Default Re: The *BEST* Solution for "THE" tensioner/pulley
amen. you've seen the light.
Old 11-01-2009, 07:38 PM
2door's Avatar
2door 2door is offline
Old 11-01-2009, 08:02 PM
Techbiker Techbiker is offline
Why is the tensioner required anyway?
I'm going to install my bike kit this weekend so I was wondering if I should just not install the tensioner and shorten the chain. What are the downsides to this?
Old 11-01-2009, 08:08 PM
Dan's Avatar
Dan Dan is offline
The chain will stretch. But can be run with out the tensioner later on.
LOL Tom, I can hear you screaming from here. (Tom and I have differing views on this)
I want 2 ride my bicycle
Old 11-01-2009, 08:19 PM
Should I go ahead and install the tensioner, let the chain stretch and then remove the tensioner later if it's annoying?
Old 11-01-2009, 08:42 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
Lets put it this way, even though I have more miles without my tensioner then with it I wouldn't recommend that anyone install their first kit without one. Consider the tensioner as training wheels for your chain.
Once you get a little more familiar with your bike and build, know for a fact that your sprocket is on truer then true then there shouldn't be any problem with removing the tensioner.
Old 11-01-2009, 08:53 PM
I think that I understand. The tensioner is actually used as a type of chain guide.
Would it be safe to remove it if I use Andy's tophat adapter on my rear disc mount and have the engine perfectly lined up with the rear sprocket? It should be perfectly true unless there is a defect in the engine sprocket.
Old 11-01-2009, 08:55 PM
bairdco's Avatar
kevlarr, i disagree. i've read thread after thread of new guys having problems with the tensioner, and IF your style of bike allows you to run without it, go for it.
as far as chain stretch goes, it's mostly your sprockets seating in, especially with CNC'd aluminum ones, not the actual chain "stretching."
mostly.
and new builders should make sure their chain alignment is true before even firing up the motor. then we wouldn't have 3 or 4 threads a day about chains falling off, spokes breaking, wheels slipping...
the drivetrain is the most important part of the build, and shouldn't be band-aided with a cheap tensioner. if you have to use it, use it right.
the end.
Old 11-01-2009, 09:01 PM
2door's Avatar
Okay, let me reiterate what I've said before.
Yes. You can run without a chain tensioner...BUT! Assure that the chain alignment and tension is PERFECT...otherwise you run the risk of derailing the chain at the rear sprocket and if you do it will probably be at a speed that could spell disaster for your rear wheel, spokes and possibly your head. Yes, motorcycles do not use a tensioner or a tensioner wheel. What we are riding are not motorcycles designed or built in a factory by experienced designers and builders. Our engines, sprockets and rear wheels are not installed to the critical alignment standards used in motorcycle factories. Our bikes are built in home garages, workshops and driveways by novice hobbiest in many instances who have a limited knowledge of essential mechaincal and engineering practice.
The tensioner serves two purposes. One is to keep the chain at a set tension and the other is to help align or guide the chain onto the rear sprocket. If you run without a tensioner and your chain alignment and tension is not right on, then you run the risk of the chain swaying and disengaging (derailing) at the rear sprocket far more than you would if there was a tensioner to make up for the misalignment that too many people build into their installs. Yes, the tensioner can be and often is a source of trouble with many first time builds. That is primarily due to the tensioner not being installed correctly. This is because the installation manuals provided with ALL kits do not address the need to align (bend) the tensioner bracket so it aligns the tensioner wheel with the chain path. Installed as per the instructions, the tensioner bracket will align the tensioner wheel with the chain stay, frame, not the chain. Because most chainstays are not parrallel with the wheel/sprocket/chain it will drag the chain at an angle to the chain path instead of running true with the chain. This cultivates all kinds of issues; noise, chain derailing, tensioner wheel wear etc. In addition the tensioner bracket has the potential of loosening under load and rotating into the rear spokes with the same results as described above with no tensioner. There has been a lot of controversy regarding drilling a small hole in the chain stay and tensioner bracket and installing a screw to prevent the bracket from moving after is has been properly twisted (bent) to achieve the alignment required. To my knowledge there is not one instance of bike frame failure due to this. Many have warned against it but their warnings are based on conjecture and theory, not fact. If there is anyone who can provide photographic evidence to the contrary, please post them here so I can see conclusive evidence of frame failure due to drilling. Tensioner problems are almost exclusively due to them not being installed correctly. I blame the kit suppliers for this because it is a universal problem which no one seems to address and has caused more problems for the new comer than any other one feature of the Chinese 2 stroke, in-frame engine kits. Let me again repeat: Yes, you can safely operate your motorized bicycle without a chain tensioner. But, if you elect to do so make sure that you understand the elements necessary to achieve perfect chain/sprocket alignment and chain tension. Those who run without a tensioner are experienced, mechanically inclined people who understand the issues involved. The tensioner, correctly installed will allow the new comer, first time builder, the mechanically challenged to enjoy their new hobby without the threat of the chain coming off and wrapping around the rear sprocket which they will quickly learn is the most effective brake ever invented. Whew! How many times have I typed this?
Still love ya, Dan
