Closed Thread
Old 10-31-2009, 07:26 PM
passivepsycho passivepsycho is offline
Default All the sudden stopped working?
Hi,
I'm new to this forum but haven't had any trouble with my gpb until recently. I installed it on an old mountain bike about two months ago and have ridden the crap out of it. (I'm well past the break in period) The problem is this, it ran perfectly the night before got me home from work no problem, then the next morning it just would do anything. From the troubleshooting guide that came with it I figured the clutch cable had stretched and now wasn't doing it's job, things like with the lever pulled the tire would still catch and you couldn't push it without a lot of effort but nothing inside the motor was happening. I've got spark, I adjusted the clutch all the way from totally slack to way too tight and everything in between with no luck, I even took the top off the cylinder head and checked for scoring, smooth as a babies butt. I'm totally out of ideas and not sure what to try. I've done so much troubleshooting that it should be in fine form when it does get running it's just getting to that part, nothing happens when you let out the clutch and you slowly come to a stop, once in a while you can hear the motor try to turn but that's it one little puff of air out of the exhaust and no go. Anybody have any ideas what I should do next? I'm not sure if I'm competent enough to go fiddling with taking the clutch apart but if I gots to I gots to. Any help would be most appreciated.
Jim
Old 10-31-2009, 07:44 PM
FileStyle's Avatar
Default Re: All the sudden stopped working?
what about carburetion? is the choke working properly? what about the float?is ther motor getting fuel?
FileStyleCycles
Old 10-31-2009, 08:01 PM
There's gas in the tube, I didn't check the carburetor because it didn't sound like the engine was putting at all just nothing. I've never had to use the choke or the gas button it always just fired right up, (guess it was a good day at the factory from what I've been reading) I'll check that in the morning.
Old 11-01-2009, 10:59 AM
Exclamation Re: All the sudden stopped working?
Ok, I checked the carb everything seems to be working just fine, so I pulled off the cover on the clutch and a ton of oil came pouring out, that doesn't seem right at all, and the clutch is very oily. What the **** do I do now? It's one of the 80/63cc motors, I don't have a brand name I got it off ebay.
Old 11-01-2009, 11:31 AM
Ok, so I pulled the whole clutch apart and somehow gas is getting in there and leaving oil all over everything. Everything is gas soaked and greasy I need to go get some brake cleaner which is what looks like a short term solution, any ideas on how the gas is getting into the clutch? Strange!
Old 11-01-2009, 04:55 PM
Bikeguy Joe's Avatar
I think this one got taken care of in another thread, so I am closing this one.
Old 11-02-2009, 08:08 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
did it get repaired? if not let me know at norms 2-stroke repair center. ok?
norms-iron-works.tripod.com
Closed Thread
