Old 10-31-2009, 03:25 AM
AnthonyX99 AnthonyX99 is offline
Default Cruiser
What do guys think of the cruiser I plan on getting that track board look it's gonna cost me 200 after taxes. I'm gonna use the 80cc jet black with this one.
Old 10-31-2009, 03:39 AM
BarelyAWake's Avatar
Default Re: Cruiser
Ya might have top bar clearance issues with that 'un - have you measured it? You'll need somthin' like 11" from the bottom bracket to the top tube at a minimum - depending on where the engine sets on the Dtube and seatpost.
The rest of the numbers if ya need em: 4 1/2" inches of clearance between pedals, 1 - 1 1/2" tubing diameter for the Dtube and 1 - 1 1/4" seatpost diameter for an easy install w/o modification (mods aren't hard, just sometimes awkward)
Old 10-31-2009, 03:41 AM
Default Re: Cruiser
It should fit fine I hope I'm going later today to check it out might be snug fit but I will bolt on if not I'll have to use a vice grip again lol heres the link Supercycle San Pedro Cruiser 26-in Comfort Bike, Men's | Canadian Tire
Old 10-31-2009, 03:45 AM
Default Re: Cruiser
I think "snug fits" look better - but they can be a serious pain in the... time investment lol I'd seriously recommend gettin' the engine kit first (if you haven't already) so you can see what yer workin' with.
Good luck - I'm lookin' forward to what you come up with
Default Re: Cruiser
Thanks I'll post some pics after I'm done building it.
Old 10-31-2009, 08:26 AM
bandito bandito is offline
Banned
Default Re: Cruiser
I like those bikes I thought of getting one myself but decided on another for my new kit.
Old 11-01-2009, 10:35 PM
Default Re: Cruiser
Got the cruiser today now here's a problem it would fit if i removed the pedals but if i raise it a bit it thiers to much clearance but the is angle right could I use a spacer behind the engine or in front and does anyone have experience with longer frames
Old 11-01-2009, 11:08 PM
silverbear's Avatar
silverbear silverbear is offline
EZ Motorbikes Dealer
Default Re: Cruiser
What about getting a wider pedal crank?
SB
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
Old 11-02-2009, 12:23 AM
Default Re: Cruiser
Crank clearance is fine but the gear is big and tubing is welded to far from the engine would shimming help with this issue thanks.
Old 11-02-2009, 07:53 AM
silverbear's Avatar
Default Re: Cruiser
How about posting some pictures as you go? Then we'll know what you're talking about regarding the pedal crank problem. If the pedal clears OK, why would you need to remove the pedals? I don't understand.
SB
