| Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. |
10-30-2009, 06:22 PM
Engine seems bogged down
I have a new 66cc engine on a beach cruiser only have about 50 miles on it.
When I run the engine at speed it runs good but if I stop and let it idle, like at a light, when I start up again it seems to be bogged down for a bit. It almost seems like the plug gets flooded and needs to burn off the excess before the power comes back. This happens each time I stop at a light.
Any ideas?
10-31-2009, 12:05 AM
Re: Engine seems bogged down
are you pedal assisting at the start up ...do pedal first to get the bike going before bringing in the motor to assist with the heavy load?? Do u slowly turn the crank to lubricate cylinder before you start motor?? do you let the motor idle for at least 3 min. after cold start?? When your finished ridding do you let the motor idle before turning it off??
10-31-2009, 04:19 AM
Blakenstein
I've been letting it warm up from a cold start. I do pedal to get the bike rolling before I bring in the motor on but when I bring in the engine I have to pedal like a mad fool to wind the engine up before it will take off. Sometimes it will give a little backfire pop as well.
oh yeah the first few day's I was riding this did not happen it's just recently.
Have not been letting it idle after taking it our for a ride. I'll start that one.
My fuel mix is around 20:1...too much oil?
10-31-2009, 07:56 AM
Sounds a little rich (fuel to air) and is definitely rich on the oil to fuel mix.
First you have to get the oil to fuel mix right, then you can tune the carb a little by moving the "C" clip on the slide needle.
If your spark plug is oily, black and nasty move the C clip UP one notch.
If the plug is light gray or white, move the C clip DOWN one notch.
After you make ANY change, run the bike for awhile before you check the plug again or make other changes.
10-31-2009, 07:57 AM
You should run 24:1 for break in, then go to 32-40:1 depending on your choice of oil and a few other factors.
10-31-2009, 10:05 AM
Originally Posted by hawaiicruiser
Blakenstein
Mix your oil according to the requirements of your engine specifications should be in your manual. I'm safe between 24&30 to one with gas/oil ratio but my motor is different from yours. I know that when I'm too rich the motor will not low idle because of less octane. Also make sure your exhaust pipe is clean. On my motor,all it takes is a little oil build up to stall my motor under load. A clean air filter is also important. Gas line could be getting clogged, spark plug could be fowled up and improper gap even the inside of plug cap gets dirty and interferes. With these 2 cycle motors it's either spark, intake or out take. For the rest, listen to Bikeguy Joe about gas/air he knows about your motor....
Did you ever do anything to your motor to try to improve performance???
11-01-2009, 06:54 PM
Thanks for your replies.
I have changed my fuel/oil mix but have not had a chance to run it yet. I'll report back after my ride to work tomorrow.
11-02-2009, 09:14 AM
Listen to Joe.
And remember, adding less oil will effectively richen your air/fuel mixture. You can see that by adding less oil you effectively are adding more fuel. Richness of oil and richness of fuel are two different things. When someone says "rich" about an engine they 99.9% are referring to fuel and not oil richness.
If the problem worsens after your new ratio, consider your rich-sounding issue from before. The bogging sounds like a rich fuel issue. A better air cleaner might improve things BUT do what's right and tune it correctly(re-jet) for that setup THEN move on to adding any mods.
Keep us informed,
Dave
KC
11-02-2009, 02:16 PM
By adding less oil, you are at the time adding more OCTANE,not more fuel ;the same amount of fuel is there, but less amount of oil. The gas will be more potent
11-02-2009, 03:25 PM
So, 32 is not a larger number than 16?
Less oil is more gas is less oil, you say to-may-toe I say tuh-mat-o.
| Thread Tools |
| Display Modes |
Linear Mode
