Old 10-29-2009, 05:50 PM
"the prussian" Shop Dogs's Avatar
"the prussian" Shop Dogs "the prussian" Shop Dogs is offline
Default hd axle build
any body ever work with the hd axle kit from piston bikes? I am try to build the wheel myself and aside from learning the spoke patterns, i'm having trouble with the "dish" of the rim because of the hub size. come to find out that a radial pattern on one side and a single cross pattern on the other works well for the dish problem but, then the spokes are 3-5mm to long? can't find 10 ga spokes the right length? anybody have a spoke thread roller? or know where to get one ? the gague of the spoke seem's a little big for the average bike shop and to small for the motorcycle shop? wheelsmith and a few others make bike wheels with spokes that guage but no luck with tooling as yet.
this forum is a great plase to find advice ,so thanks in advance The "prussian"
we few, we happy few, we band of brothers.
for he that shares the road with me shall be my brother. be he nare so vile this ride shall gentile his condition . and pedestrians now afoot will hold there manhood cheap when passed by a motor bike geek
Old 10-29-2009, 06:59 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
Default Re: hd axle build
From the digging I did about a month ago a spoke roller will set you back over 2 grand and the cheap "do it yourself" roller (about $150) only does 16 gauge spokes.
Old 10-29-2009, 07:21 PM
ocscully ocscully is offline
The tooling you are asking for is not easily available. The Tools that are available Phil Wood Spoke Machine and the Morizumi Spoke Machine are both quite expensive and neither of them have the additional dyes for handling 10g spokes. You might have better luck contacting a supplier like Buchanan Spoke and Rim, Inc. or The Wheel Master to see if they could provide you with the proper length spokes.
One other thought about your project. The idea of using radially laced spokes on a rear wheel of a motorized bicycle in my opinion is a very marginal at best.
Old 10-29-2009, 07:27 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
If the spokes are only 1/4" too long, you can just build the wheel & then grind the tips off the spokes with a grinder!! (so they don't pop the inner tube)
I've done it twice now, it works fine!!
Old 10-29-2009, 08:04 PM
ride65 ride65 is offline
I am waiting to here form a person who has roller dies for 11 guage spokes for the 150 dollar machine. But have been waiting. Will have to get back to them. the 150 maching is not the best on small spokes but should work ok on heavier spokes. The spoke thread is old honda nipples on there small bikes. Huskie bicycles sells 11 and 12 guage spokes.
Old 10-31-2009, 10:46 AM
ocscully : I tend to think your right about the radial pt. but is the only one that seem's to work?
the problem is of course that the tire hits the stay when the wheel is laced w/a2or3 cross pattern.
as for grinding the spokes (vmb) got that covered it's a thread legnth issue. can get the nipples down far enough to begin truing?
thanks for the links i"ll check with them , and if anybody finds a good machine for under $200 let me know.
Old 11-01-2009, 09:27 AM
Talking Re: hd axle build
only took five days but the wheel is on the truing stand! turns out that the three cross pattern w/o the last cross being"laced" did the trick... thanks for all the advice(u know who u are)
anybody that has never built a wheel should give it a try it's a true test of ur skills and in the end was kinda fun
