Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle > Motor Bicycle Safety
Motor Bicycle Safety Share safety tips for motorized bicycles. Some of these bicycle engines will reach great speeds and need respect.
Old 10-29-2009, 03:28 PM
2door's Avatar
2door 2door is offline
Default Fuel Tanks and Fire
Guys,
This is a strange one but one that needs to be shared here because all of us, except our electric compadres have fuel tanks and gasoline to contend with.
An old firefighter buddy of mine, recently retired, knowing that I have motor bikes, called me and relayed a story he had read about in a firefighter newsletter he subscribes to.
A man was working on his motorcycle and had removed the gas cap. Presumably to keep dirt out and to keep the fumes in, he covered the hole with a strip of cellophane tape and when he was ready to put the cap back on he ripped the tape off and, apparently, there was a static spark that set off the vapors. He was not badly burned but his bike and garage were destroyed by the ensuing fire. The man was not smoking and there were no other ignition sources in the vicinity of the bike so static spark was ruled the culprit. It is not known if the tape or the man's hand generated the spark but with that in mind I plan to be a little more careful whenever I have the fuel tank open for any reason. This is probably one of those 1 in a million cases but still something to be aware of.
Old 10-29-2009, 04:18 PM
george_n_texas george_n_texas is offline
Default Re: Fuel Tanks and Fire
They make you attatch a ground cable before you pump fuel out of a tanker truck for the very same reason.
Old 10-29-2009, 06:45 PM
the willi the willi is offline
also guys dont have your cell phones in pockets or be using them while fueling this is good story tobe talking about because you will not here about these storiers unless you are in gas bus. or fireman etc. or envirmental work. TO everyone here at this site, your family is counting on you to safe! HAVE A SAFE TRICKER TREAT!!
Old 10-29-2009, 06:56 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
Urban legend.
snopes.com: Cell Phone Use at Gas Pump
Old 10-29-2009, 06:59 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
i was thinking (luckily, just thinking) about fire the other day, when i installed a new clutch cable. my favorite method of making sure the end of the cable doesn't fray, is to put some heat shrink tubing on it.
with a lighter.
and it's right underneath the air filter.
the filter has a sponge filled with gas inside of it.
think about that the next time you're torch soldering or heat shrinking that cable end.
(i was also smoking at the time, since i had a lighter in my hand...)
Old 10-30-2009, 12:52 AM
Technocyclist's Avatar
Technocyclist Technocyclist is offline
living dangerously? must have good insurance...
Regardless if it's left or wrong, the opposite is always right.
Caution: This hobby is habit forming.
Old 10-30-2009, 01:46 AM
noco noco is offline
dont use matches to see how much fuel is left in the tank!!!!
Old 10-30-2009, 08:28 AM
omegaunderground omegaunderground is offline
Great post 2Door, good looking out Its also a habit of mine to never fuel my bike in the garage, or mix my gas in the garage as well. I always open the garage door go outside with my bike and gas can and do it there.
Old 10-30-2009, 12:28 PM
don't use a vacume to clean up a fuel spill! (Motor's brushes make sparks)
Old 10-30-2009, 02:44 PM
fasteddy fasteddy is online now
Rode with a bunch of bikers in the early 60s and one guy used to check his gas with a flash light. Worked great until his buddy stuck his head into the tank filler to take a look too.
Should have put the cigarette he had in his chops, out first. It was not pretty.
Steve.
