Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 05-31-2008, 01:28 PM
cityevader's Avatar
cityevader cityevader is offline
Default Walbro carb...which one?
I've read numerous references to Walbro carbs being used. I've tried googling them to see what bolt spacing they have, but no luck. There's quite a few to pick from, but no listed bolt pattern (my 70cc has approx 40mm spaced manifold bolts).
Anybody have a model number to help me out with?
Old 05-31-2008, 02:29 PM
Bikeguy Joe's Avatar
Default Re: Walbro carb...which one?
I do recall someone mentioning the model number on this web site....don't remember who or where.
Old 05-31-2008, 07:40 PM
Dave31's Avatar
Dave31 Dave31 is offline
I searched like crazy for you could not find part number. Easy Rider seems to be the one who use's it alot, you could try to PM him
Old 05-31-2008, 08:30 PM
Dave31's Avatar
Ahh, I think I might have found it; part number HDA63
Post #43 page 5
http://motorbicycling.com/f15/spy-pi...ion-243-5.html
I would still PM Easy Rider to find more info, I think I read somewhere that some mod's have to be done for it to fit.
Old 06-01-2008, 01:12 AM
cityevader's Avatar
I feel your pain...I do!
Searching like crazy has gotten me very disappointed!
Even stopping into a few small engine shops got me down, as they can apparently only look up parts on a "by-model" basis. Like such and such log splitter or trencher or weed whacker needs such and such carb... no dimensions or specs or bolt spacing.
SSSIIIIIIIIIIGGHHHHHH!!!!!!!!
I think I'll PM Easy Rider tomorrow.
Old 09-05-2008, 05:49 PM
badjester badjester is offline
I'm not sure about coming up one that's "bolt-on" ,but, I'm using a walbro carb that I got from pocketbikesunlimited.com and it works great. I did have to drill the manifold provided out to fit the "stock" intake manifolds diameter and drill/tap one hole through the "stock" intake manifold to match a hole in the carborators manifold. It was pretty easy and it works grrreat.
It was called a 16.5MM remote purge carborator, was for any of the 2-stroke 48cc pocket bikes and I just chose the 48cc model, though all of them are for 48cc engines the intake manifolds differ a bit bike to bike.
good luck...
Old 09-05-2008, 07:20 PM
misteright1_99's Avatar
Heres one that is a clamp on.........
http://motorbicycling.com/f13/high-p...ound-2314.html
I run a mikuni, and it is also a clamp on......
http://motorbicycling.com/f13/18mm-m...rade-1895.html
Old 09-23-2008, 06:51 PM
europorsche914's Avatar
europorsche914 europorsche914 is offline
I just ordered a Walbro HDA-63 (which is what Pipelyne told me they are using with their reed valve kit) from Russo Power Equipment - Walbro Carbs Carburetors (Walbro Carbs) for $53.50 +shipping if any one is looking for a source...
Old 10-02-2008, 12:40 PM
stats about the HDA carb including mounting hole distance: Walbro | OrderTree.com (US)
Old 10-14-2009, 10:35 PM
speedracer831 speedracer831 is offline
I JUST FOUND THE EXACT SAME CARB ON EBAY FOR 34 BUCKS. thought id let you all know cause i think its the best deal ive ever seen. with shipping its 39, and the seller is 100% positive customer feedback. look up walbro hda 63 carburetor on ebay
