Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 10-22-2009, 04:40 AM
impression impression is offline
Default Magnet nut removal
Gday, well i'm wanting to install my pull start and that requires me to take pff the nut that holds the magnet on to place a piece on there and then put it back on.
I'm wondering how i go about removing said nut :/
Old 10-22-2009, 07:51 AM
Bikeguy Joe's Avatar
Default Re: Magnet nut removal
Take off the gear cover and stuff a rag in the gears, that will hold the engine from turning so you can remove the nut.
Old 10-22-2009, 09:04 PM
Blakenstein's Avatar
Blakenstein Blakenstein is offline
Don't your motors have fly wheels? My motor has a flywheel that even has fan blades on it.My magnets are inserted flush with the face of the fly wheel. Nobody here in this forum has a system like mine.I see complete kits advertised for just over 100. Just the motor for my kit is over 300 dollars and thats American.
P.S. Comes from Island Hopper American Chain Drive,in Florida the kit I have has been sold out for along time
Old 10-22-2009, 09:33 PM
2door's Avatar
2door 2door is offline
An impact wrench works great. No need to hold the gears or anything. A word of caution here: The crankshaft where the magnet mounts is very small diameter and easy to bend. If you need to remove the magnet, and I don't know why you would, you need to be careful when doing that. Use two large screwdrivers wedged under the magnet and carefully 'wiggle' the magnet off the shaft. Use caution and don't get heavy handed here. You do not want to bend that shaft.
Old 10-23-2009, 10:13 AM
large allen key wedged in at the right place did the trick.
placing it perpandicular to the engine @ 90degrees
Old 10-23-2009, 12:55 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
sounds like your engine isn't a china 2-stroke like most of us mess with here on the forum. So next time you have a question about your engine etc. please tell us or with a photo show us.
With the type of engine you have it must look more like a briggs for those I use a tool called a strap wrench or the tool made for holding the flywheel then remove the flywheel nut also a special tool for some with the starter nut. to remove the flywheel either the flywheel puller or a special knock off nut to remove the flywheel.
You can wedge the flywheel with what you were talking about but be careful doing so as you can every easily break off a flywheel fin.
norms-iron-works.tripod.com
