| Motorized Bicycle Pictures Use this forum to share pictures of your motor bicycle. |
10-22-2009, 04:47 AM
Re: imp's rebuild
Nice 1 bro! now hurry up and finish, we go cruising.
As for the magnet nut, on my old motor i jammed something between the magnet and the magnito frame like a screwdriver. Im sure theres a propper way to get it off,i just dont know it.
10-22-2009, 04:52 AM
Re: imp's rebuild
very nice build, I dig the bracket you made for the down tube, I went the easy way and drilled my frame.. wish I hadn't lol.... good work man
10-22-2009, 05:08 AM
Re: imp's rebuild
yah, the downtube bracket/plate is actua;;y a pice cut off from bunning's scaffolding that they use in the store :P
took about 30mins to cut through it with a hack saw... bloody dense !@#$ that stuff
also i left the fold there ( above the engine mount point ) as to give it horizontal strength on the top end of the plate, also helps in not letting the engine flex from side to side
10-22-2009, 05:10 AM
Re: imp's rebuild
yah, just need to get that nut off so i can get the pull start installed as kicking over the engine by foot is not a good idea with a shift kit... i sheared 2 bolts in one go by doing that on my first ride at a set of lights i had the idle a bit low
10-22-2009, 05:42 AM
Re: imp's rebuild
Dude grab flat headed screwdriver in ya left hand and a ring spanner in the other, the Magnet sorts looks liike the batman symble yeh, poke the screwdriver (vertical) in through the front left of the crank NOT THE SIDES.
when you turn the spanner it will all lock up and she should wind off.
10-22-2009, 02:54 PM
Custom Builder / Dealer
Re: imp's rebuild
Dooood... It's not a good idea to run your carb that far out of level.
10-23-2009, 09:42 PM
Re: imp's rebuild
ok, went for test ride today, went about 25km from home and chain broke aswell as a nut came off my front mount bracket and the allen bolt in the middle collar of the shift kit's drive shaft came out somewhere along the way.
replace nut > check
fix wide open throttle proglem > check
fix high idle > half a check, still a bit high.
replace allen bolt in collar > to do
replace broken chain link > to do
10-23-2009, 09:54 PM
Re: imp's rebuild
Be careful trying to remove the magneto magnet. The crankshaft is only about 5/16" diameter at that point and it will bend easily if too much lateral force is applied. Use two large flat blade screwdrivers and 'wiggle the magnet off the shaft. Don't get heavy handed or you'll be replacing the crankshaft. There is a crankcase seal behind the magnet; don't damage it.
| Thread Tools |
| Display Modes |
Linear Mode
