Old 10-21-2009, 06:27 PM
ycowboyfan1313 ycowboyfan1313 is offline
Red face cluch problem
when i disengage my cluch to stop, the engine revvs and when i let go it lets out ALOT of power and the bike almost leaves me behind. i have a kill swich but it dosen't take long for this to start happening.
Old 10-21-2009, 08:06 PM
marts1 marts1 is offline
Default Re: cluch problem
Dosen't sound like a clutch problem. Check that your throttle is installed properly. Sharp bends anywhere on the cable? Does the throttle feal smooth? If not the throttle maybe trouble with the carb.
Old 10-21-2009, 08:54 PM
Spunout's Avatar
Spunout Spunout is offline
MB Builder Extraordinaire
i was thinking kinked cable as well. OR is your idle set too high?
Originally Posted by Dan View Post
sn0rk.
Originally Posted by Bikeguy Joe View Post
You are one sick man spun, I like that quality in a person.
Old 10-21-2009, 09:49 PM
If you find nothing wrong with that stuff check for air leaks.
Old 10-22-2009, 05:37 PM
well my throttle cable was too long so i rolled it once in a circle but it isn't bent sharply. ill look at my carb...
thanks
