Old 10-20-2009, 11:35 AM
tbolt76 tbolt76 is offline
Default wierd sound
When I was pedaling with the engine off i heard a sound like somthing was rubbing hard against somthing but i looked and saw nothing its fine with the engine running but now the sound just stopped and i dont hear it anymore any idea what this could have been?
Old 10-20-2009, 12:53 PM
2door's Avatar
2door 2door is offline
Default Re: wierd sound
If you are using a 2 stroke in-frame motor without a centrifugal clutch the sounds that you hear are probably the manual clutch, chain/sprocket. Even with the clutch disengaged and if the rear wheel is spinning there are parts moving that can make strange noises. If you're certain there is no interference with rotating parts and your chain tension and alignment is right, I wouldn't worry about the sounds. Just keep an eye on things and make sure there is nothing external rubbing.
