Re: Dax titan friction drive
One thing I have found out is that the Collar bolts on the Clutch pack can be very close to the Bell. Sometimes they can touch and make a bell or metallic noise. If this is the case, then you need to put the 4 flat washers on top of all 4 spacers and only use the lock washers with the bolts. These flat washers can space the engine out enough so that the collar bolts do not touch the Bell. If a collar bolt hits the bell too hard, it can break the collar bolt on the clutch pack !! Yikes. Not good. So.. Make sure to listen for this. It is so close, some touch, and some do not. We are talking 1000th of an inch or so . Point being, it is close for sure which is what you want. But not too close. Again, the fix is to move the flat washers to the other side and space the motor out some. An easy fix for sure. Enjoy the ride...
