Old 10-17-2009, 06:42 AM
caraddict96 caraddict96 is offline
Default WONT START.. again lol
i Have A Hard question, if the cdi module is bad can you still have spark??
My bike wont start I tested my magneto and got all the right readings. then tested the cdi module, the readings where all Wrong!..... BUT i have spark when i walk my bike FAST with the spark plug against the head....
NOTE:1. Im really good with a multi meter so i know the settings where accurate. 2. the bike is getting gas and has good compression. timing is good also. 3. Im using msd wire and have been for a while. 4. ngk bp5hs installed.
Please help.
thanks in advanced
Old 10-17-2009, 08:02 AM
Bikeguy Joe's Avatar
Default Re: WONT START.. again lol
What happens if you pour a tiny amount of gas in the spark plug hole, then try to start it?
Old 10-17-2009, 08:10 AM
ive tried that. ether, and that was just incase because it already had a wet plug and gas dripping from the tail pipe after numerous times of trying to start it
Old 10-17-2009, 08:11 AM
o and just incase i didnt make the answer clear lol. it didnt help at all, it didnt even make it putt a lil
Old 10-17-2009, 08:51 AM
george_n_texas george_n_texas is offline
Just talkin out loud but just for grinns disconnect the kill switch just in case it is faulty and drawing some current. I also gotta wonder if the float needs adjusting...could be flooding? Fortunately I have a nice big hill to crank with.
Noticed you are in Stillwater...I worked out of the Wal-Mart DC in Ochelata just south of Bartlesville north of Tulsa a few years ago...nice country, I like Oklahoma.
Old 10-17-2009, 09:13 AM
well when i first got my kit i never included a kill switch since they can often times go bad. and also killing your fire by grounding it out isnt the best.
i have never ajusted the float, i did try starting at the top of this hill. and while going down i tried every choke and trottle ajustment possible. it just wouldnt start.
i dont think its the float.... it was running fine and then i go to start it.... tries and putted a lil then nothing.
o and i do love Oklahoma.
Old 10-17-2009, 11:02 AM
spad4me's Avatar
spad4me spad4me is offline
Did it rain.
Did you wash your engine.
Remove the cover on the magneto housing.
Dry off any trace of moisture.
check for shorts as well .
Loose connections.
Also check the cdi wires by gently tugging on them.
Motorized bicyclist
Old 10-17-2009, 11:14 AM
ok so i just got back from checking everything. it did rain a while back.....
but it ran the day after that just fine.
ive had the cover of earlier and no water.
i checked the wires and the continuity is good all the way up till it goes in the box.
ive tried new gas too.
Old 10-17-2009, 11:49 AM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
try to clear the engine leave the spark plug out gas off throttle wide open choke off pedal to clear out any fuel. install clean new spark plug gaped at 0.020. try to start first with the fuel off then on see if it won't fire up. you said it was dripping fuel out of the pipe sounds like you flooded the pi$$ out of it.
3 things to make your engine run
spark at proper time
fuel
air
If your missing one of these or in the wrong amount it will not run
you need a proper oil mix for a 2 stroke too much oil will ruin your day, fowl the spark plug carbon up the rings and combustion chamber. mix at 20 to 1 first for break in then go to either 32 to 1 or 40 to 1 for syn oil or follow directions on the oil bottle. Do mix your fuel in a separate fuel can. regular gas is the best for these engines.
I've been using Polan 2 stroke syn. oil at 40 to 1 in the bikes this seems to be working very well no smoking and more power from the engine.
norms-iron-works.tripod.com
Old 10-17-2009, 12:41 PM
OK well looks like i have something new to try lol.
on the three thing... thats not always true its very important to have proper compression too. o and also the right mixture of air and fuel.....
my mix is perfect 25 to 1, and a brand new batch too. i mix it in tank but i shake good and only do .3 gallons per tank so its not to full. has been working great for me. and also my plug looks grand when running properly lol...
i use high performance echo 2stroke oil.
no smoke
im gonna try the ur suggestion though. thanks. ill let you know how it goes
