Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Tavern > Suggestions
Suggestions This is the members forum. Help to make the motor bicycle engine kit forum better with your suggestions
Old 05-28-2008, 11:26 PM
cityevader's Avatar
cityevader cityevader is offline
Default Engine performance vs. engine performance
In my field as an automotive technician (mechanic) we have a term for engine performance problems.. driveability, (which happens to be my line of work, along with electronics, but I digress) which is quite different from engine performance in terms of increasing performance, rather than a lack of normal performance. It would be wonderfully helpful to separate the two with distinct sections, so the posts about sputtering under load won't be alongside to the bottle debate.
Old 05-29-2008, 04:40 PM
Bikeguy Joe's Avatar
Default Re: Engine performance vs. engine performance
Yes, performance doesn't always mean to "hop up" or "modify for racing purposes".
Old 06-14-2008, 09:56 PM
cityevader's Avatar
Okay, how about a "troubleshooting" section separate from performance upgrade section?
Please?
Old 06-14-2008, 11:05 PM
flyboy605 flyboy605 is offline
I thing a troubleshooting section would be great, I have been trying for two weeks to get my 99 whizzer to run properly, no luck yet, its better but not right,it idles well, runs ok at low speed but when I try and accelerate it bogs down never seen 25mph, it is running very rich and I need a 74, and 72 main jet, if you have one I would like to buy itThanks Paul navion@q.com
trouble shooting forum has been added in the bicycle motor main forum
Old 06-15-2008, 04:58 AM
tinkerfinger's Avatar
tinkerfinger tinkerfinger is offline
Can you dissasemble the muffler on that model to check if its restricted?
If your not sure, ask a friend first!
Old 06-15-2008, 10:20 PM
Hi and thanks for your reply, the bike only has 10 miles, and I did check the muffler .
Old 06-17-2008, 03:44 AM
I dont know if this helps, but I have about same miles. My carb began to fall apart. the fuel inlet loostened up and poored half my tank on the ground. I suggest retightening everything on these kits. You never know what you will miss. As far as actual changes in the powerband. Its all about the pipe. Short pipe, good bottom end power & less top end. Long pipe, less bottom end power but more top end speed.
