Old 05-01-2013, 07:03 PM
JTona23 JTona23 is offline
Default Re: Motorized Bicycle Take a Tip...Leave a Tip
Hi, just wondering how port matching the inlet and exhaust ports of a 2-stroke will further increase engine efficiency
Old 05-01-2013, 07:54 PM
maniac57's Avatar
maniac57 maniac57 is offline
Don't expect huge gains, but well worth doing. Every little bit helps...
If more is better, then too much is just enough.
If you can't afford it, build it yourself.
Old 05-04-2013, 01:24 AM
Here's a tip for riders who need to use a magnetic card key to access a garage gate/arm. For years, I've carried my access card in my wallet. Then I'd had to stop @ the entrance and dig out my wallet, scan it, then put my wallet away before riding up the ramp. Since I always keep my wallet in my front left pocket, I simply get close to the scanner and lift my left leg slightly. This activates the gate, without having to fumble around for my access card.
I'm so happy!
Old 05-04-2013, 01:47 AM
BarelyAWake's Avatar
My bad 5-7HEAVEN, I read that wrong & thought this at first;
Old 05-04-2013, 10:18 AM
Vin Vin is offline
I have a question for the group...I've been riding my motorized fixie around my college campus...maybe put 10 miles on it. I noticed this morning that the rim on the rear wheel is pretty dirty and covered in spots of oil. First thing I think is to clean it off and see how much accumulates over the course of my trip to the cafeteria. A fair amount caked up. I realize that it may be running too rich, but what about the fact that oil is getting on the rubber of my rear tire? Does anyone have any advice on this for me? Thanks
-Vin
Old 05-04-2013, 12:35 PM
SuperDave's Avatar
SuperDave SuperDave is offline
If you look, I'll bet your exhaust tip is greasy too. Exhaust blow out of unburnt 2 cycle oil. Happens to me until the cat converter gets warmed up, it can take 10 minutes or more of riding to heat up enough to burn all the fuel/oil unburnt by the motor.
If it's a relatively fresh motor & you're still breaking it in with double oil as recommended, this is normal, just carry a rag with you. If not, then you may be running too rich an oil mix or the carb itself is jetted too rich (try dropping the carb needle a notch, see if it helps).
By the holy power of Love, Life & Laughter, I commend you to Go Forth & Be Awesome!
Old 05-04-2013, 01:29 PM
LOL, I thought the same as I typed "lifted my leg".
Old 05-06-2013, 12:23 AM
Old 05-06-2013, 01:38 AM
-Vin
I've used exhaust hose fromwww.davesmotors.com to extend my exhaust past my wheel. You can also point the hose away from the wheel.
I also get less oil splatter, now that I use 100:1 mix of fuel and Opti-2.
Old 05-07-2013, 11:18 AM
buck1234 buck1234 is offline
Thumbs up Re: Motorized Bicycle Take a Tip...Leave a Tip
I came across a handlebar grip removal replacement trick. Windex to get it off and hairspray in the grip to keep it on. Suppose once on, laquer thinner to pull it off again.
Off topic "Something that really works" Like most folks I've been peeling a banana from the top. Gently pinch the bottom of the fruit and no more tearing,cutting or tearing the top with your teeth.
Buck aka buck1234
Tags
MotorBicycling.com
