Old 04-17-2013, 04:07 PM
Jumpa's Avatar
Jumpa Jumpa is offline
Default Re: Motorized Bicycle Take a Tip...Leave a Tip
Hey Buck, you might already know this but ..If you go on your computer to START/run/ in the run box type in " charmap " you will see the. sign along with around 20,000 other useful sings and symbols
Just my 2
Old 04-17-2013, 06:24 PM
Jumpa's Avatar
Years ago when I scored this dark Blue Clear Creek SCHWINN Made to represent as their 100th Anniversary bike in 1995 the guy had a more expensive Black larger clear Creek with stock front and rear racks well I was at a yard sale last month and I saw this beat up black monsterly large Clear Creek SCHWINN with only the front rack on it I inquired with the owner he said his kid bought it years ago off of the same guy I bought mine off of . well I snatched it up quick for $60 bucks I wish I took some before photos of it but I dove into fixing it so fast I didn't even think of it here are a few pics of them both together again after many years apart This baby is gonna make one fine motor bike and finally I have a bike that fits me If you could have seen her before I touched her up a bit it doesn't even look like the same bike rusted / broken cables, So I ripped into it w/ new bearings, cables , twist sifters , levers , etc etc . just stuff i had laying around didnt spend a dime extra over thew 60. Motor in the mail!.
Old 04-17-2013, 08:14 PM
maniac57's Avatar
maniac57 maniac57 is offline
Awesome score!
If more is better, then too much is just enough.
If you can't afford it, build it yourself.
Old 04-17-2013, 08:42 PM
Jumpa's Avatar
the more i ride it the less & less i want to put a motor on it it is so quiet , she is so smooth, tight . Full torque on the pedals and not even a ....um creek no pun
Old 04-17-2013, 08:46 PM
Jumpa's Avatar
This is the 21" after I put the motor on her in the spring of 2012 after I totaled my much to short wheel base "Huffy" by hitting a patch of black ice the winter prior , and sliding into a dumpster full speed ahead cracking the frame on the huffy and moving a fully stuffed 2 yard dumpster back 2'feet from the impact. So I swapped all salvageable parts basicly just the handle bars onto this "SCHWINN Clear Creek" and got a much more dependable and a lot less wobbly M.B.
I suspect the frame of the Huffy was cracked prior to my dumpster diving debut (:
Old 04-21-2013, 09:38 PM
Wickedest1's Avatar
Wickedest1 Wickedest1 is offline
Here's a tip if you ever needed a smaller more sturdy bracket for your idler tensioner bracket..had a left over 1 " u-bolt bracket...took itto the table grinder and ground off most of the sharp points so that the concave dip was about 1/8" deep...the brackets already sharp edges help stop the bracket from getting yanked into the wheel...
Thats a lot of moving parts...hope it all works...
FD4E
Old 04-24-2013, 10:55 PM
T_Raw T_Raw is offline
my motor ran fine and I noticed the intake valve was leaking. took it off and the gasket was fine so I just tightened the bolts and one of the heads broke off so I tightened it as much as possible. also today I had it sitting outside after work and it started raining while I was sleeping so the bike did get wet today. after I put it all back together I drained the carb hopped on and took off but the engine wouldn't run, it will start but it won't stay running pulling a load and it wont idle either. I kept tinkering and trying things loosened the idle screw and it ran well for a couple of minutes it did idle really high though. so I do not know if it wont run right because of the intake valve or the bike getting wet. it has been wet before but not ridden for a few days afterwards. and it ran fine earlier I rode it to and from work. any help would be appreciated.
Old 04-25-2013, 05:50 AM
rustycase's Avatar
rustycase rustycase is offline
Gutter Rider
Traw, seems to me like you should have posted in another one of the forum threads to get the help you need... Perhaps a moderator will help out here, when noticed...
I'm not sure how you determined your intake valve was leaking, but after reading your post, I suspect you may not have really meant 'valve' ???
..Maybe the intake manifold?
What kind of motorized bicycle do you have?
Would you please tell us a bit about your mechanical experience ?
Any chance you could take a picture of where you broke off the bolt head?
That kinda should be repaired !!! before you do anything else !!!
Good luck,
rc
My goal is cheap, reliable, personal transport, below the tax collector radar. Fun counts for a lot!
Old 04-25-2013, 04:31 PM
RC yes I meant the intake manifold I'm pretty sure it was leaking causing my engine not to reach top speed so I took it off & checked the gasket I have already replaced the bolt I broke with another one of the same size. I haven't started the bike & do you know what forum I should post in? I'm new to the forum but I have decent mechanical skills
Old 04-25-2013, 06:28 PM
SuperDave's Avatar
SuperDave SuperDave is offline
Probably not the rain that caused it to run bad, but an intake leak WILL cause a runaway/high idle & poor top end performance. This applies to 2 strokes & 4 strokes. Replace the stud/nut-bolt and maybe use a bit of RTV gasket sealer (not too much) to seal up the gasket, should get it to run decent.
Norm's Repair Center is a good place to post if you have questions regarding problems, he's quite knowledgeable and willing to share his wisdom for free.
By the holy power of Love, Life & Laughter, I commend you to Go Forth & Be Awesome!
Tags
MotorBicycling.com
